Running MT as a 3WD
TX
Running MT as a 3WD
So, one of my rear drive bones broke. I am waiting for a replacement to come in the mail. Will it hurt my truck to go 3 wheel drive?
RE: Running MT as a 3WD
Actually it will only be front wheel drive. If you break a rear dog bone all the power goes to the front wheels. It will be hard to control and can burn up your tranny.
ORIGINAL: traxxaspede
or you could switch servos and use the other one.
Yes it would be ok to run rear only. Just dont run front only.
ORIGINAL: twomanytoys
Switch servos? He broke a dog bone what does a servo have anything to do with?
AL
If you do decide to run it in rear wheel drive, you might wanna take both dogbones out of the front, and the front trans. dogbone, that way your front diff won't have any power to it at all, it'll be much less strain on the tranny and front diff.
ORIGINAL: Brett185
Ive ran most of my tourers on 2wd from 4wd when ive broke a bone hasnt done any harm just take it easy until the part is replaced
Geez, bad info alert in many of the above posts!!! Unless you have a center diff, it doesn't matter (to the transmission) one bit if you are running in front wheel drive or rear wheel drive, the tranny will see the same amount of stress either way, since it splits the power 50/50 front/rear. I cant imagine what you guys think will burn up in a MT tranny in front wheel drive that wouldn't burn up in rear wheel drive..... If you DO have a center diff, it will be just as hard on it running in rear wheel drive as it will be in front wheel drive, you don't want to do either in that case, but since you say its a monster truck, im assuming no center diff. Here is a tip for when you ask for help, tell us what truck you are running....
The only difference (assuming no center diff) will be that you will actually have more acceleration if you run in rear wheel drive, since the weight transfers off the front tires on onto the rear when you accelerate, and you will have more braking if you run in front wheel drive, since weight transfers to the front tires when you brake.
Personally, I would run it in rear wheel drive for the added acceleration. And remove the front drive shaft if possible, or if not then at least remove the other front dogbone.
If you have a center differential, don't run it at all till you have all 4 wheels powered, but since you say its a Monster Truck, I'm assuming you don't have one....
OR
ORIGINAL: dacaur
ORIGINAL: Budget Monty
False. Weight transfer is to the rear under acceleration, and the rear tires would be less likely to spin. A fwd will be much more likely to spin the tires, and be more likely to spin which ever tire has the least traction through the differential, and high speed diff operation can generate a lot of heat and kill it (Either being a gear diff or ball diff). Have you ever driven a FWD RC car? I was suprised to see that many people that posted realized this, but I thought it was even funnier that the guy that post wrong information is trying to call everyone else out, lol! (AKA you)
ORIGINAL: dacaur
ORIGINAL: dacaur
read it again, I said .....it doesn't matter (to the transmission) one bit..... I didn't say anything about diffs. I was simply stating that the guy who said it would burn up the tranny was wrong, notice also that I did recommend going with rear wheel drive.
As far as burning up the diff, that's unlikely, if its a properly set up ball diff, its unlikley you will have just one tire spinning in the first place, since both tires will have about the same amount of traction. A gear diff will be more likley to spin one tire, (you can easily spin one tire in rear wheel drive too), but anyone with half a brain will let off the gas when that happens, since the truck wont be going anywhere....
OR
ORIGINAL: dacaur
ORIGINAL: dacaur
