Need Beginner Advice.
Hi, I'm just looking for some general advice on where to buy my first RC petrol/nitro car, Ideally I'd like something that's good for off road, any suggestions would be greatly appreciated.
I've always liked rally cars, and would love to get an RC Rally car, but I really don't want to get one of the cheap toys that you see often in the toystores - I want something a bit quicker with a bit more umph, and ultimately have an engine.. rather than a motor.
A rally car may be the wrong choice for me for as a beginner, I'm open to suggestion on that one, but the buget I'm looking at would be around £200 ($300) at the moment. (Also would a rally car be able to handle grass should I take it down the park?)
YT.
YT.
ORIGINAL: Chris_RC
Tamiys has a couple rally cars I think, I would look them up.
VA
i havent sencen any actual rally cars in rc.( only onroads people have moded a little) if there are then its not very popular
i think a buggy could be a good chose for what you want to do. probly more functional then a rally car.
CA
ORIGINAL: yorkshiretyker
What are the advantages of onroads? that buggy's don't have?
TX
Let's quit beating around the bush. Get a MONSTER TRUCK. Trust me. Pick a price you want to spend and find a few you like, then come back here and ask if they are any good.
I personally recommend an electric as your very first RC, preferrably an off-road one, a truggy or monster truck.
I say electric at first because of the simplicity and you can focus on learning how to tune your chassis (camber, caster, ackerman, droop, preloading, shocks oil weights, diff oil weights, gear ratios, clutch engagement set-up, and so on). Then, once you feel the electric cannot give you any more challenge, then you can either go brushless + Lipo and/or go nitro.
nitro adds another dimension to setting up the RC, that is engine tuning. And tuning goes a long way other than just turning needles: it includes plug selection, pipe selection, header length slelection, head shim selection, etc.
VA
actually now adays electric and nitro are about the same performace wise. the only real disavantage electric has is runtime. now it just depends on what is more your style.
electric is more plug and play. cleaner, silent
nitro challenging when you start, learing how to tune your engine takes its time( it can be very fusterating and discuraging). you have to care(maintance) for the engine, break-in. its a lot of fun once you get the hang of it
about onroad car well i love onroad. it does have the limitation that you can basicly only run the car on a hard surcare (asfalt, concert, ect)
ORIGINAL: HJJFFFAA
Can you even adjust setting that will change the Ackermann?
(I have not ever played with my ackerman settings, so I do not really know exactly which components will have the most inpact. The onroad guys and buggy/truggy racer guys know these tricks intimately though.)
NJ
I don't know. I've never messed with it. Can I alter it with the toe links?
EDIT: Looking at my IGT I found I can adjust the ackermann, albeit only slightly. There is only one different setting that is adjust on the steering rack and no adjustability on the hub carriers.
