Differences in Servo Types?
Old 04-26-2009 | 08:47 AM
Default Differences in Servo Types?
Can anyone explain a couple things about servo types?
What is the difference in performance between analog and digital?
My Futaba radio has 2 modes - PPM and HRS. The HRS mode only works with digital servos. What is the difference between modes?
What is the difference between 3 pole, 5 pole and coreless motors?
Hitec has "Karbonite" gears in some fo their servos. What is that?
Bryan
Old 04-26-2009 | 11:44 AM
Default RE: Differences in Servo Types?
http://www.rchelicopterfun.com/rc-servos.html
Old 04-26-2009 | 02:49 PM
Redharris's Avatar
Digital Servos are More Accurate and Repeatable in both THROW and CENTERING.
You can think of it This way: A digital servo turns right 3 degrees,(click, click, click). Now you bring it back to Center position,(click,click,click).
Each of these "Clicks"is a Precise and Equal movement of the servo. It is quite accurate.
An Analog servo is not as Precise, because its positioning is controlled by a Brushed Potentiometer (instead of a Digital circuit) and it is inherently
less accurate and Repeatable than a digital system.
Your particular Futaba Radio was designed Specifically to take advantage of this Digital Revolution. (I THINK you have to use Futaba digital servos though, in HRS mode). Resolution, Response, and Speed will be Enhanced while using HRS mode. It will also be more Expensive.
3 and 5 core servos have conventional motor construction. That Being wound copper wire in the Rotor/Stator.These are BRUSHED motors and are susceptable to wear and tear where the Brushes contact the Stators. More Cores are supposed to offer a Greater Degree of controllability.
Coreless means the Rotor is a Strong magnet. Its Motion is controlled by magnetic Fields, so there is no actual contacts (Brushes) to wear out.
These are the New Digital type of servo and Should have a longer service life.
Karbonite is Marketing Speak for "Strong Plastic Gear"...Lol.
Servos cannot be ENTIRELY metal, due to radio interference (Noise), that Glitches the signal. All servos have at least one plastic (Karbonite )gear for this reason.
Old 04-26-2009 | 03:15 PM
jpilkinton's Avatar
ORIGINAL: Redharris
I was wondering this info myself.
Also, I always wondered why on metal gear servos there was always one plastic gear.
I learn something new every day.........
Thanks bro!
Old 04-26-2009 | 03:34 PM
also correct me if I'm wrong...I do believe you can program a digital servo if you have a servo programmer....
Old 04-26-2009 | 03:36 PM
jpilkinton's Avatar
ORIGINAL: firebird78
Yep, I read about that too somewhere else. You can program the endpoints and something else?
I also read that you can use digital servos on any radio.... Is that true?
Old 04-26-2009 | 03:38 PM
I cant see why you couldnt....the stock am radios for say the torpeda are analog radios...and the steering servos are digital I beleive
Old 04-26-2009 | 04:26 PM
Thanks for the great answers guys. Really good info.
Old 04-26-2009 | 06:07 PM
Redharris's Avatar
Yes....Here is a Link to HiTechs Programmer/Tester
http://www3.towerhobbies.com/cgi-bin...&I=LXSYU0&P=ML
