Help with something to do with clutch or tranny
TX
Here is what happens.
all the sudden when I give my truck gas it doesn't move. Sometimes it will though. But only for abouta minute or so. Then If I let it idle for a few seconds, it may or may not start to drive again. It revs up fine, but wont go forward. I tightened the slipper clutch and it seemed to work a little, but still has the same problem. Does this mean I need a new clutch bell and shoes? Or what do you think may be wrong with it. BTW, it's a Mini MGT.</p>
CA
RE: Help with something to do with clutch or tranny
How many gallons are on the car? I would look for anything like driveshafts that arent connected as even 1 hweel driveshaft will cause it not to move. if not that, replace clutch shoes/springs/bearings. Is the engien idling like it normally does?
