himoto python...does any one no about them
<span style="font-family: Comic Sans MS"><span style="font-size: medium">hi i have a 1/10 python buggy and it wount start and i dont no why and it is leakeing gas from like the transmision where the 2 gears are and also from the starter (i have a tiger start) i dont no what the problem is it started fine like 2 weeks ago and now notting ...and also does any one no the carb screw setting ..thanks pat</span></span>
yea thats what i thought to but it holds gas like it will stay in there for a week with out spilling out than when i go 2 start it thats when it starts 2 leak
maybe its a fuel line, could leak under pressure, you shouldnt leave fuel in your tank if your not going to run it for a while. 2 1/2 out on the high needle and 3 1/2 out on the low needle are good starting point.
dude your fuel line needs replaced...take of the fuel line and blow through it with your finger covering the other end...the reason your leaking fuel from the starter (backplate) is cause it prolly needs sealed...just ur average blue automotive silicone will do the trick...I believe Rich and Adam did a video on how to seal your engine,I would suggest watching it..
and if some reason your fuel line holds pressure reattach it to the tank...then take off the line to the exhaust...blow through one end with your finger over the other...should hold pressure till ur fuel lid pops up</p>
yea im gonna try it out and im gonna let ya no whats happens thanks..do you no if there is any python like threads that i can lookat i dident see to much onbuggy thanks
i have a himoto python and the 1 way just keeps busting what the deal . what do u himoto people suggest does any 1 have have any extra they would want to sell kool
it would start on 1 pull but when u hit the throttle on the tx it just revs up spinning the clutch bell and turning the speed gears. its brand new by the way it not even been ran 2 hours / when it first started acting like this i pulled the gear set apart and cleaned the oil out of the 1 way is started to seem fine but then 5 min later it did the same thing so i pulled it back apart and inside the 1 way the lil roller pins just fell out i guess it was faulty i havent purchased another 1 yet i havent heard any 1 else have problems with theres so i didnt know weather to go with the single speed and do a way with the 1 way or should i give it another shot any suggestions on this here thanks guys Anthony
I'm lost on this.....your one way bearing is acting up cause when you hit the throttle the clutchbell spins which causes the speed gears to spin?....not sure what your calling the speed gears but i assume its the spur gears....when reving up a nitro its spose to spin the clutchbell and spin the spurs.....the clutch is engaged by centrifical force....
the one way bearing is inside the rear of the engine...behind the pull start or roto start start.....if the one way goes bad USUALLY you cannot crank the engine...if the rc wants to take off while you start it or when its started at idle its usually a clutch issue
everybody on here with R/Cs sign up at hobzob.com its free and its an awsome site u can findHIMOTO RACING there and me DRIFTINGISMYHOBBY they alwasy have competetions were u can win money and meet sum kool people on here
