1/8 Scale Truck Bodies
Old 03-30-2002, 01:20 AM
polygonguy
Default 1/8 Scale Truck Bodies
DOES ANYONE KNOW WHERE I CAN FIND GOOD 1/8 TRUCK BODIES? I CAN FIND A TON FOR 1/10 SCALE. WHAT ABOUT FOR 1/8 SCALE???I HAVE A NITRO QUAKE. THANKS FOR ANY HELP!
Old 03-30-2002, 05:37 AM
pilothyer
pilothyer's Avatar
Default Body To Fit Nitro Quake
I have fitted a body that is for the T-Maxx on my Nitro Quake, it is a Pro Line Humm Vee Urban. It is made from .060 Lexan which is a real plus over the stock Quake body. The front body posts will fit ok, but you will need to modify the rear by adding a support piece across the body posts..........It looks good and also has better clearance of the tires when the chassis bottoms out with the wheels turned than the Original Quake body.................
Old 04-09-2002, 05:33 AM
RC Jack
From what I have seen, there aren't any! What I would recommend is find out the wheelbase of your truck and match it to the body style you want. You may have to do a liitle searching, tho, for a 1/8th scale.
Most trucks have about a 12" wb, but you can get away with a body with 11"wb.
HPI & Atomik (tower hobbies) make a couple that fit the bill. Tho, both are Ford, one is an F-150 and the other is an F-350.
Don't feel too bad, I'm looking for a Dodge Ram....one that looks realistic, that has at least an 11"wb.
Hope this helps
Old 04-09-2002, 11:51 AM
T28pilot
Default I used a 1/10 too
I used the Proline cadialiac escalade body for my TXT-1...come with body mounts and everyting....sure makes the truck look bigger
Old 04-10-2002, 01:00 AM
RC Jack
I did manage to find a 1/8 scale truck body. It's a Ford F-150, with a 13" wheelbase! BUT, I forgot where I saw it. I'll look for it.
Old 04-24-2002, 11:32 AM
ksebago
My Feedback: (57)
I use a chevy suberban 1/10 scale, on my nitro quake, with a remote glow, by kavan in the back,so I don't have to remove the body to glow up.This look's and work's great. Thank's Ken
Old 05-02-2002, 09:47 PM
turbojoe
My Feedback: (8)
I've got an OFNA Monster Pirate body on my N.Q. Got it real cheap on eBay. Looks much better than the original.
