10 amp charger
My Feedback: (32)
MN
RE: 10 amp charger
I always thought that you were not suppose to charge a lipo at a charge rate higher than 1C (so 5A for a 5000mah lipo). Have lipos improved that much so they can be charged faster?
RE: 10 amp charger
Don't do it.... or you will be buying new batteries very quickly... doubling the charge rate halfs the life of the batteries... Having a better charger however doesn't hurt any... I have a bunch of zippy's and if they say they charge at 2C, its most likely for marketing because some of the other companies claim theirs do... save you batteries and charge at 1C...
OH
RE: 10 amp charger
ORIGINAL: savagecommander
ok ok...explain that one to me- how does charging a lipo at 2c halve the life of the battery. i need facts.
Newer batteries have different construction and chemistries that allow higher safe charge rates with less reduction in battery life.
MI
RE: 10 amp charger
ok- so why would that manufacturer advertise them a 2c charge? maxamps is saying they have cells that are 5c charge. whats the big idea? lipoo chemistry is different now and can handle higher charge rates or what? i think more research is in order.
OH
RE: 10 amp charger
If it's rated for it, then it's very possible that you could charge your batteries at 2C without any issues. But it's just something to keep in mind.
FL
RE: 10 amp charger
Maximum cycles are generally rated at 0.25C, and the number of cycles a battery will last goes down as you go up on the charge rate and discharge rate.
A battery companies rating depends on the company and what they consider an acceptable loss of cycles. Of course the newer technology makes that number less and less so that they can market them as 2C or higher without concern of too short a battery life.
These numbers are just for an example and not accurate.
Battery A 2000mah- gets 1000 cycles at 0.5A charge rates
Battery B 2000mah- gets 1000 cycles at 0.5A charge rates
Battery A gets 850 cycles at 2A charge rates
Battery B gets 800 cycles at 2A charge rates
these are acceptable losses for both so both could be sold as 1C charge capable
Battery A gets 700 cycles at 4A charge rates
Battery B gets 550 cycles at 4A charge rates
Some companies may see 700 cycles as a reasonable amount of loss and market this battery as 2C capable
But battery B loses to much of its usable life at 2C so it can only be sold as a 1C
Again these numbers are strictly made up for explanation purposes and do not reflect actual batteries. But you can see that any increase in charge/discharge rates shortens the life of the pack.
