Need Help..plz read
Old 07-11-2003 | 09:33 PM
Default Need Help..plz read
You know the radio transmitter at the car. who pulls the stick that decides the speed.. mines quite broken,each time i put the break on it changes view. However! when istart the car, it goes full speed. i dont do anything... It went ok a few times but it stopped after a few seconds
and next time it went high speed agian
and as we all know, the car cant start whit full speed any ideas what to do? buy a new speed controll reciver set?
Old 07-11-2003 | 11:58 PM
uh................................................ ........................
hmm let me try and figure out exactly what your trying to say.
i think its
the radio, pulls the stick?changes view?
i have no idea what yoru talking about but do this.
#1 make sure your batteries are charged in anything that has a battery in it.
#2 make sure with your car off and your radio off, you are able to control the car ( give it gas and brake, turn the wheels)
#3 make sure your carb only open up to the thickness of a credit card when your hold the brkaes on. look inside the carb with the air filter off and you will see a small space that gets bigger when you give it gas.
did you mess with the screw in the side of the carb?
#4 type slower and try and have it make more sense.
i see your not from usa so i wont get on you about you typing.
Old 07-12-2003 | 12:01 AM
dan1220's Avatar
Default Re: Need Help..plz read
what?? I have no idea what your saying
Old 07-12-2003 | 03:05 AM
soapsuds43's Avatar
i think i can simplify this
the throttle servo in the car is broken when i press the break it reverses but when i start the car it pegs to full throttle even when i dont even mess with it what should i do? buy a new servo, reciver?
i hope this is what you mean
Old 07-12-2003 | 03:07 AM
soapsuds43's Avatar
what i would do is open the reciver and make shure nothings in it if its fine then i would replace the servo or get a new gear set for the servo you have
Old 07-12-2003 | 03:24 AM
dan1220's Avatar
take off the air filter, and look into the carb. THere should be a 1mm gap. Did you take your servo arm off at all? if so, make sure that when the servo is in the IDLE position, that the gap is 1mm.
Old 07-12-2003 | 12:57 PM
no, no ,uve got it all wrong... There's a screw that hold the plastic merge part whit the stick that changes the speed where the air filter sit at the engine.... and once the plastic piece thats connected to the Radio reciver move, it changes rotation. So, u've got everything in normal when u start, then u start..driving.. and pull the break, and the white plastic merge whit the stick.. whos connected to the radio, it cant go as high as the radio reciver wants me to, that makes it change rate.. and once u try and fix it ,it screws up even more! so now i cant start my engine whitout the engine goes at high speed.... ill send in a pic of the place im talking about.. this is not my car.. but its just a exemple i found on google.
see the speed changer on the car? the white thing that changes the speed on the radio reicver.... first mine start pointing up,after i push the brake and lose the break the natrual is down instead of up.... we've been trying like maniacs to fix it but it wont work!
Old 07-12-2003 | 01:00 PM
Yea, Soap, something like it.... sorry for my bad english, its hard to find the right words when it comes to explaining a area i dont know what the name is of it hehe
Old 07-13-2003 | 02:30 AM
soapsuds43's Avatar
are you talking about the servos arm? the servo is the little box that is connected to the reciver and when you move the trigger or wheel on the transmitter (radio) it moves they controll the car
