brushed motor help
Old 06-17-2010 | 04:52 PM
Default brushed motor help
I gave a Peak racing 19x2 raven sv2 brushed motor and it stopped working, but I'll just bet it needs brushes, but how do I check if the brushes are good and if they arent good, how do I replace them.
ID:	1454485   Click image for larger version
ID:	1454486   Click image for larger version
Old 06-17-2010 | 05:05 PM
suburban_hooligan's Avatar
Default RE: brushed motor help
<p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><font size="3"><font face="Calibri">pop the springs off and pull the brushes out. <span style="mso-spacerun: yes"> </span><span style="mso-spacerun: yes"> </span>if they are bad (broken or really worn), then unscrew the screw that's connecting the shunt wire to the end bell.<span style="mso-spacerun: yes">  </span>the brush is now uninstalled.<span style="mso-spacerun: yes">  </span><span style="mso-spacerun: yes"> </span></font></font></p><p class="MsoNormal" style="MARGIN: 0in 0in 10pt"><font face="Calibri" size="3">its also a good idea to go ahead and pull the arm out and have the com turned.<span style="mso-spacerun: yes">  </span>and then break the new brush's in</font></p>
Old 06-17-2010 | 05:31 PM
All right I reada nice long thing online, but the onl question I have is, will any brushes work or will only certain ones work</p>
Old 06-17-2010 | 05:39 PM
<p class="MsoNormal" style="margin: 0in 0in 10pt"><font size="3" face="Calibri">its been so long sense iv really messed with brush's i don't really remember.<span style="mso-spacerun: yes"> </span>im thinking there are lay down and stand up brush's and they are not interchangeable.<span style="mso-spacerun: yes"> </span>i think there is also a bunch of different sizes and compounds.
</font><font size="3" face="Calibri">the easiest thing to do is find the part number of the stock brush's and buy those.<span style="mso-spacerun: yes"> </span>takes the guess work out of it</font></p>
Old 06-17-2010 | 10:45 PM
mrbonez's Avatar
im pretty sure the sv2 is the angled brushes its getting kinda hard to find brushes for any type brushed motor but i think this is what you need http://www.horizonhobby.com/Products...rodID=ORI41130 you can get them alittle cheaper without the springs http://search.horizonhobby.com/index...d=129492CEA24F hope that helps
Old 06-17-2010 | 11:04 PM
Jake I can show you how to change them its pretty easy.
