Stiffer shocks in rustler?
Old 07-05-2010 | 11:52 PM
Tsz
Default Stiffer shocks in rustler?
is there any way to make the shocks stiffer in my rustler?
Old 07-06-2010 | 12:03 AM
1320Fastback's Avatar
Default RE: Stiffer shocks in rustler?
Put the spring clips on that come in the kit, change the springs, change the oil to thicker oil, change the pistons inside the shock to ones with fewer/smaller holes, change the mounting of the shocks to a more upright location.
Old 07-06-2010 | 09:25 PM
Tsz
how many clips can you put on one shock?
Old 07-26-2010 | 07:31 PM
ORIGINAL: Tsz
as many as you can fit on the body. they come in different thicknesses so the number varies, but what you really need to do is put stiffer springs on there, then maybe some heavier oil
Old 07-26-2010 | 08:42 PM
qoisdhc oqina's Avatar
My Feedback: (-1)
Thicker oil doesnt make it stiffer/softer.It makes the response of the shock faster or slower.
Stiffer springs or preload spacers makes it stifffer.
Old 07-26-2010 | 10:02 PM
ORIGINAL: qoisdhc oqina
no kidding. Never claimed the oil makes it softer/stiffer, but a thicker oil will definitely compliment a stiffer spring
Old 08-15-2010 | 01:49 PM
if you dont know how to change the oil just buy different stiffer shocks or put the c clip spacer things in that way you can modify it to your liking also
