Nitro RC engens
Old 07-17-2010, 06:11 PM
Shi-Maxx
Default Nitro RC engens
I have been reserching nitro RC engens for a couple of days and i have read artical after artical and none answer my ?'s. How is the crank case presserized and how does the fuel make it up threw the intake Port?im stumped and i want to lurn and understand these nitro engens to make myself better and smarter. plz Help.
Old 07-17-2010, 06:44 PM
proanti1
proanti1's Avatar
Default RE: Nitro RC engens
The piston draws fuel into the crank case through the crank during its upstroke. As the piston moves downward the fuel in the crank case compresses, once the piston hits bottom dead center it passes some ports on the sleeve. These ports inject the compressed fuel into the cylinder. The piston them moves up and the cycle repeats.
http://en.wikipedia.org/wiki/Two_str...ry_inlet_valve
Technically, a glow powered two stroke is rotary valved, because of the intake tube that runs through the crank, which has an opening that allows fuel/air into the crank case once per complete rotation.
Old 07-17-2010, 06:52 PM
Shi-Maxx
Thanks man  i appreciate it and will post if i have any more ?s.
