RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Is it possible to attach........ (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/1383237-possible-attach.html)
neap38 12-28-2003 03:36 PM
Hi does anyone here know if its possible to convert my pull start 16nt engine to a rotary start using a drill to start up the engine?
sort off need to know before tomorrow because i have to visit my lhs by then.
thanks:eek:
customst-15 12-29-2003 10:32 AM
RE: Is it possible to attach........
Try checking into the hgi yank eliminator, the only scary thing is the rear engine bearing is left exposed
nitromacguyver 12-29-2003 11:22 AM
you might if the pullstart uses a one way with a hex shaped out side becaues you could use a ratchet socket with a small adapter to attach it to the drill.
neap38 12-29-2003 11:36 AM
ok thanks...
how much would both of them cost
neap38 12-29-2003 11:44 AM
i think im gonna try using the second idea as its free and im cheap. Ive been told thoe it would be easy to strip the one way bearing.
How could i attach the one way bearing to a drill with out damaging it when i use it.
neap38 12-29-2003 01:00 PM
thanks for your help i know what i am going to do and how im going to do it:)
nitromacguyver 12-30-2003 11:24 AM
go to a hard ware store and fine the correct size socket and ask about and adapter. they are generally about 3/4 of and inch long, one end is mad for a 1/4 inch drive socket and the other end is hex shaped so it fits the drill easily. for both you are talking $5-6 dollars tops
neap38 12-30-2003 11:59 AM
ok kewl.. all i need is the adapter i found the socket but i couldnt get it to fit in my drill[:@]
thanks ill get a adapter tomorrow
