HPI Dash
Does anybody have any links or advice on how to mount dual motors on an HPI Dash? What motors would you recommend
RE: HPI Dash
Dash is electric right? I thought 2 motors gave it more torque not more speed. Plus it would be hard to do. Just get a BL setup.
RE: HPI Dash
well all i know is your gonna have to fab. your own motor plate.
RE: HPI Dash
Im kinda new to the terms so your gonna have to explain what a BL setup is. Two motors gives it more speed, i guess depending on the setup. I saw a website(linked from a post) that had a project where someone put two motors in an XXX or sumthin. They were trying to break the land speed record with it.
RE: HPI Dash
I found out how to do the electrics for a dual motor setup. Depending how you set the motors up decides if you have torque or speed. Everything is in the electric cars forum under dual motors
RE: HPI Dash
bl=brushless. when people say that they are meanin a motor that has no brushes, springs,or what ever a mod motor has dat need replacement.a brushless is the way to go it you have 230 dollar.(for a novak bl) you get the speed of a 10turn motor(lower the turn the faster)and run time of a 3400mah battery if running 3300.and i think with dual motors its mainly tourqe and you will get less runtime. but yea when you get done post some pic. up!!
RE: HPI Dash
if i do try dual motors then i have to look into either wiring up a dual battery(saw it done somewhere) or getting better ones. Ill only have four packs so that wouldnt give me a spare and i just spent all my money on buying my car
RE: HPI Dash
so your gonna have a 12cell battery with dual motors. umm you might be able to get away with that knowing that idont know nothin about the esc its stock with
RE: HPI Dash
the stock speed control is the servo connected to the receiver. i know how to wire everything up with any ESC or MSC(manual speed control/stock) would more torque give me more speed? and i need a detailed intruction on how to wire two battery packs together(6 cell 1500mAh)
RE: HPI Dash
Is it possible to put two driven pinion gears on a main drive gear? would this be in too much danger of stripping something?
RE: HPI Dash
I have heard that it is nearly impossible to upgrade any part of the dash. I had one and by the looks of it the motor is a smaller size then the 540 motor that is standard in the rc world. Because it is really not a hobby car at all I wouldn't try it. Instead I would get something lkike the HPI Sprint. But you don't have to listen to me. Go ahead and try it.
RE: HPI Dash
im thinkin about selling my dash as soon as i get it because i want a car i can upgrade. any takers? PM me
| All times are GMT -8. The time now is 04:27 PM. |
