tmaxx tranny problem
my t maxx only has second gear all my gears look good im not really sure how to adjust the shift point i think that might help any suggestions please let me know by email thanks chuck
Adjusting shift point
Your instruction book covers how to change the shifing for advancement or to delay.
i dont have a manuel for it that is one of my problems to
Take the little plug off the tranny, spin the gears until you see a slot in the white gear inside. Then hold the spur and spin the little shaft that sticks out one end of the trans until you see a setscrew, now, on mine there is two screws, one that goes directly toward the shaft you are spinning, the other goes beside it, that is the one you want. tighten it up a little at a time to see what happens. does that make any sense?
yea im going to try it when the rain quits but what about no first gear thanks chuck
The problem is it instantly shifts, before you know it, if you do as I said youll fine tune the shift point to where the engine revs up a bit before it happens. One of the screws will be in all the way, dont loosen that one, one should turn in farther, do that one
ok ill try it thanks chuck
Troubleshooting
Check out Traxxas.com for troubleshooting tips.
OR maxxtraxx.com
JonhHV,
U-is the man!!!!!! I was having problems with my trans. read your adjustment advice.......... Purfect. My T-Maxx runs like new. Thanks for the help! |
Very happy to hear!! Now go have fun
| All times are GMT -8. The time now is 02:07 AM. |
