RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   The car do not run (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/279873-car-do-not-run.html)
Navap 09-23-2002 10:09 AM
The car do not run
My car is new. I did the break in on the engine, and the car runs well.
But now, when should be bether, the car stop, start at first try, the engine runs, and the car do not move, I do not know what to do more. The car is the Nitro ST 15 from Tower Hobbies.
thanks
NAVAP
dirtman-RCU 09-23-2002 09:35 PM
The car do not run
It runs but doesn't go? Check your spur gear and on back to the wheels. Gotta be there somewhere?
dbow 09-24-2002 01:41 AM
Rock
Maybe you have big rock stuck in Diff.
Maybe rock in belt, or maybe roll backwards, then better.
LOL
Just messing,
Check the belts etc. for debris, and SWEEP that parking lot before you run.
Also check your clutch. If you cant resolve by troubleshooting, take the whole thing apart and put it back together, replacing any worn parts.
You will certainly stumble onto the problem as you put it back together.
Dbow
FlyinRazorback 09-24-2002 03:44 AM
Re: Rock
Dbow
Dbow, you're not right man :cool:
Bonefrost 09-24-2002 01:48 PM
The car do not run
I actually had a rock stuck in my spur gear!And it's not funny man!hehe
BNZ'
scale only 4 me 09-24-2002 02:55 PM
The car do not run
what kind of car are we taking about here???
dbow 09-24-2002 03:27 PM
Rock in diff
Flyinrazor,
lol
No harm intended just having a little fun.
Dbow
Navap 09-24-2002 10:22 PM
The car is not running
The car is a Tower Hobbie Nitro ST 15.
The car run well on the brack in, now i do not know what more to do, the engine start at the first try, run, and the car do not move. :cool:
dirtman-RCU 09-24-2002 11:08 PM
The car do not run
1 Attachment(s)
Tighten the nut on the spur gear, and make sure the clutch and spur gear are meshing properly. Then while you are at it, you should back out the screws that hold the recoil start on and add loc-tite and retighten. Same goes for the head bolts!!
Navap 09-24-2002 11:47 PM
The car do not run
Men, the picture appear be my car, and believe, i did that.
dirtman-RCU 09-25-2002 02:27 AM
The car do not run
1 Attachment(s)
So it's still not going? Maybe it's in your diff? I took mine apart to put in the bearing upgrades. It's not too bad to tear down and check your gears in there. Also check the c-clip on the opposite side of the spur gear. It goes thru the case and is fastened on the other side. Careful, it seems to me that the c-clip is kind of an odd-ball size, and tough to find outside of a hobby shop.
cuguy27 09-25-2002 03:20 PM
The car do not run
Could be that if his engine is coming up to speed and not engaging the clutch that his clutch shoes are shot. You should check to see if the clutch bell is spinning!
Enzodw 10-29-2002 10:14 PM
The car do not run
Change the batterys in the back of the car
that was my problem
