RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   failsafe problems (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/2869939-failsafe-problems.html)
Goaferboy 04-12-2005 03:11 PM
failsafe problems
when i got my hyper 7 tq rtr the throttle servo was doing the opposite of what the trigger was doing. i used the controller to reverse the signal or whatever so it worked properly. i fitted a failsafe and now instead of turning off the throttle when there is no signal it puts the throttle to full. is there a failsafe that has a switch on it to control what it does when there is no signal?
ncgrunt 04-12-2005 03:31 PM
RE: failsafe problems
It should have a button or something on it to set it... check your instructions.
Goaferboy 04-12-2005 03:37 PM
i already looked on the one iv got and it only has 2 lights on it and thats it.
iv ordered [link=http://www.modelmaniacsonline.co.uk/products.php?CatID=107&SubCatID=110&ProductID=1891 &Title=MICRO+FAILSAFE%2FLOW+BATTERY+INDICATOR&ManC ode=4401515]this[/link] so i think iv sorted the problem
ncgrunt 04-12-2005 03:43 PM
You must be missing it then. The failsafe is worthless if you can't set it.
Goaferboy 04-12-2005 03:58 PM
i just had one last look before i ordered the new one and i noticed one of the things i though was a light was actually a set button. problem solved. works a treat. thanks for your help
