RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   clutch help! (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/2999983-clutch-help.html)
r40 05-22-2005 03:26 PM
clutch help!
i just took the 2 shoe clutch off of my 15 fe,i im not sure how the 2 springs are supposed to be mounted back in the clutch (do they sit on the posts or not and which direction they go). any help is welcome links, pics, advice, anything at all
Bucknut 05-22-2005 08:40 PM
RE: clutch help!
sorry I don't know the answer to your question.....I have a clutch question too.
How do you know if the clutch shoes are bad? They were white and now look a burnt brown. When I open the throttle the engine revs up but the truck only moves very slowly.....I'm hoping it's the clutch because it's the easiest/cheapest thing to replace - but other than it being brown I don't see any difference in how it looked before.
Any suggestions for what the problem could be?
r40 05-22-2005 09:43 PM
RE: clutch help!
if it takes alot of throttle to get the truck moving, then i would say that it is the shoes, replace them and that should fix your problem
Bucknut 05-22-2005 10:04 PM
RE: clutch help!
I think I found my problem....
The roll pin that latches onto one of my rear wheels broke....I just got new wheels/tires and when I put them on I must've over-tightened them and broke that pin.
As for your question, are you sure you mean spring - and not shoes? Mine doesn't have a spring....the shoes on my RC10GT face clockwise - meaning the pin is on the most counterclockwise side and the rest of the shoe faces the clockwise posistion.
r40 05-23-2005 12:53 AM
RE: clutch help!
there are 2 little springs
http://www.hpiracing.com/buyhpi.htm
then put "a827" under search, thats the spring in mine (2 of them) sorry but i dont know how to link or post a pic.
RC ROMEO 05-23-2005 08:22 AM
RE: clutch help!
This should help u out a bit...just copy and paste the link. let me know how u make out
http://hpiracing.com/graphics/instr/a910p1.jpg
r40 05-23-2005 11:23 AM
RE: clutch help!
thank you, i figured it out now
