RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   locking diff (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/3294059-locking-diff.html)
rcmaster123 08-24-2005 10:27 AM
locking diff
how do u lock your diff?
degsc 08-24-2005 10:31 AM
RE: locking diff
you buy a spool to replace the sock gears. or you can pack the diff with grease to get a limited slip effect
Ahab 08-24-2005 10:37 AM
RE: locking diff
...or fill it with Epoxy resin (permanent)
...or fill it with silly putty (temporary)
ross_jsy 08-24-2005 12:28 PM
RE: locking diff
what do u need it for, unless u r crawling or goin over very rough terrain i wouldnt bother as it wrecks your turning circle
rcmaster123 08-24-2005 04:33 PM
RE: locking diff
i put some big tires on m tc3 and made it 2 wheel drive so i can go in dirt and stuff, but in the grass one whell spins
cossie 08-24-2005 05:24 PM
RE: locking diff
to lock my diff all i do is tighten it all the way up
xtremraptor 08-25-2005 02:44 AM
RE: locking diff
BAD HORSIE makes just what you need
[link=http://www.badhorsie.com/products/diff-lock-grease.html]diff locking grease[/link]
cossie 08-25-2005 05:18 AM
RE: locking diff
ORIGINAL: ross_jsy
a locked diff in the front gives you more steering
pawraith 08-25-2005 10:46 AM
RE: locking diff
ORIGINAL: cossie
ORIGINAL: ross_jsy
but a locked diff in the REAR gives you less steering. rcmaster said he has removed the front wheel drive.
i had read in a previous thread that someone used candlewax to lock their diff. this would probably be cheaper than sillyputty but just as temporary.
ross_jsy 08-25-2005 11:39 AM
RE: locking diff
yeah that was the thread i started. so if i lock my front diff i will hve a better turning radius. i was going to lock it but i also like to drive aswell so i didnt
rcmaster123 08-25-2005 12:11 PM
RE: locking diff
YEAH I FIGURED OUT opps, that i can tighten it to make it like a spoil
cossie 08-25-2005 12:22 PM
RE: locking diff
lol spoil i think you mean a SPOOL lol
rcmaster123 08-25-2005 12:37 PM
RE: locking diff
yup thats what i meant'
SqueedilySpooch 08-27-2005 02:42 PM
RE: locking diff
im pretty sure i answered this same ques from maybe one of u in this thead. Basically a front locked spool gives u alittle bit less off power steering and maybe a speed decrease(usually entering the corner or a turn) However u accelerate through and out of the turn/corner faster than a diff. Also u get the advantage of breaking still unlike the front one way. Front one ways allow u to jus cruise through a turn using no breaks which gives ur car max speed outa the turn. However its more sutable on larger turns and sweepers and is hard to learn to use if u used a diff sometimes also no breaks...jus spin outs. A front spool would give u some of the performance capabilities of the one-way with out the trouble but give u breaking ability up front which wont give u spin outs. I personally run a solid spool i made for my car.[8D]
