RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Please Help!!!! (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/360690-please-help.html)
987982 11-11-2002 11:42 PM
Please Help!!!!
Ok here is the list of problems with my Maximum ST:
When i break, the engine (torq 16) cuts
When i give it gas the car doesnt move forward, and if i give it a lot of gas it moves, but very slowely, and when it drives on grass, the car get stuck and the wheels wont move. I can here the engine working, it sounds good, but it wont move. Anyone know whats wronge and a way to fix it?
thanks
trey3670 11-12-2002 12:37 AM
Please Help!!!!
sounds like it could be two things,first check the clutch make sure its kicking and turning the spur gear,if thats happening it might be your diff,im not familair with the model but i would bet on that,good news if its the diff its only gonna cost 10$ bucks ta fix,bad news ya gotta tear in to the tranny but thats fun for me,pay attention to how tight the diff is when ya put it back together too tight burn out to looose wont move /and/or burn out,see ya!
snoopster 11-15-2002 07:24 PM
Please Help!!!!
Hey!!
Sounds like the slipper clutch to me!!!
Try tightening it slightly by doing the screws near it up!!!Not to far though or it will act as if the brakes are on all the time!!Cant be good 4 da engine!!!
NITRO RULES!!!
snoopster 11-15-2002 07:27 PM
Please Help!!!!
Oh, by the way...
It could be cutting out because your throttle linkage is set slightly wrong so that when you break there is no gap in the carb. so the engine cant breathe!!!try moving the throttle trim up slightly!!
gubbs3 11-15-2002 09:34 PM
Please Help!!!!
You should always, always always always always always always always always always always always always always always always adjust the idle speed with the idle speed screw, NOT THE TRIM. That way, when you push the brakes you don't kill the engine. I'm sort of peevish about this if you can't tell.
Start by adjusting the throttle trim so when you are at idle and you push the brakes there is no change in RPM. Then adjust the idle screw to set the idle speed just fast enough so it idles reliably. There is no reason you should ever need to use the throttle trim.
987982 11-15-2002 11:19 PM
Please Help!!!!
ok thanks! ill have to try that.. when i took it into the hibby shop i also found i had a massive hole in the fuel tank, which i have NO idea how got there...ran fine all day no bashing at all, so i have a tank on order right now. the problem i had with the car not moving should be fixed (wheels were not tight enough) so thanks for the info ill try it as soon as i can!
Bonefrost 11-15-2002 11:24 PM
Please Help!!!!
Yep.That was my first leason.It's usually way off whenever I buy a car.
First thing I do!
BNZ'
