RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   ? tank tread using servos (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/3788932-tank-tread-using-servos.html)
discgolfer72 01-17-2006 08:27 PM
1 Attachment(s)
hey i need some help building a monster rc not makeing treads but it works like them i hav two servos that drive wheels wanting to use rc elect to run my idea is to use a reciver and connect the two servos ( shown here) with a reciver chanel one and two for indpendent wheele movment (ie. one turns foward while other turns backwards to turn)it should work right
also the way their wired now only uses 2 wires do i need to use all three wires with my futabe connectors or can i just use 2 and if i need to use all three where would yhe 3 wire go
please help building a mobil missle pad
ps want to speed it up to would a bigger reciver bat fry reciver
R/C fan-addict 01-17-2006 09:43 PM
RE: ? tank tread using servos
I doubt that servos will drive it since a. they are really slow and to drive it anywhere will take forever and b. servos are only meant to go a certain angle (like spin 90* in each direction) but can not perform a full rotation
J_D 01-17-2006 09:49 PM
no
- my brother has made robots that use the servos to propell the wheels - the servos are special - full rotational ones. and you can buy fast and high torque servos.
discgolfer72 01-17-2006 09:54 PM
these r speical servos their is no petionimeter or limiter from what i understand that is what is used in robot war machines i have a tank tread kit on order for buildin an m1 abrams that has the speical servos like in pic but are pre wired for an rc reciver
this is an old robie jr that has a lost remote i want to get running as a mobil missle launcher to go wit my tank i know it will work i just need to know if i need the 3rd wire for my reciver to run it or if i just need 2 since i really dont need a sensor wire (no petionimeter)and if i do where would i connect it to
for bolth im using tamiya staic model kits as body parts
ps using same setup as this to actualy launch rocket remotley also plan on turret being functional (example /up/down/left/right movment)
i have no brob with limits either i have a 8 channel reciver and remote
all vids at end ov thread
http://www.rcuniverse.com/forum/m_36...tm.htm#3786888
discgolfer72 01-17-2006 10:39 PM
1 Attachment(s)
here is a vid of the components im dealing with went over with camera and working some parts
http://www.rcpics.net/img/72040
and some extra part pics mabey to be used for working lights and sounds
discgolfer72 01-17-2006 11:12 PM
sorry but also dont get distracted by the board i wont be using it aat all unless i can figure how it controlls the lights sounds but for now i just want to get it mobile using a reciver
help!
discgolfer72 01-18-2006 12:30 AM
1 Attachment(s)
here is the connector and heres what i need to connect ^^^^^ do i need the signal wire will it work without when connected to reciver on channel 1 and 2
alo anyone know what the max bat voltage i can run into my reciver
using standard futaba reciver now once all done ill be using 8 channel remote and reciver
R/C fan-addict 01-18-2006 06:36 PM
max receiver voltage is 6 volts for a standard receiver
discgolfer72 01-18-2006 07:06 PM
1 Attachment(s)
under further4 disasmbl foun out i have motors thought i was going to have to go slow with this since it was servo drive bbut these look like 380 size motors gonna go ahead and put 2 baja motors in here and run with my esc wont have 2 stick controll but now ill be able to zoom to the target (my friends nitro truck:D hehehe)
discgolfer72 01-18-2006 07:48 PM
well not going to work i have to have the ind wheel control so if any one knows if i really need thi signal wire to connect or not it would be great
R/C fan-addict 01-18-2006 11:57 PM
you should mount real rockets on to it. MAy I reccomend estes rockets? get some tiny little ones paint em to look like missiles and then stick in a size a engine and foom! I am tempted to buy a mini heli and attach one to the bottom with a release mechanzim and a starter system! lol :D
discgolfer72 01-19-2006 07:17 PM
one step ahead of ya thats was the whole bassis of my proj
started with my rc10 with a kick
pluss it will be fun to try n blow up my buddys junk nitro car[sm=bananahead.gif]
smokingcrater 01-19-2006 07:46 PM
yes you do need the signal wire. servos are stepper motors, they require a signal to tell them to move and how fast... as far as the limited rotation, it is EASY to modify any regular servo for unlimited rotation, takes about 5 minutes counting the time to take it apart and put it back together.
discgolfer72 01-19-2006 08:06 PM
theese r not servos thougt they where but on dissasamble found 380 motors
if u use my reciver can i just plug + - in on a futaba conector to each motor and plug into my reciver so i can have ind controll over each motor (using ch 1 fr one motor ch 2 for other ) i dont expect too much speed just need to make this thing move
so i can start on the turret and rocket ingintors
discgolfer72 01-19-2006 10:55 PM
well thought someone here might know but oh well im just going to do it if i fry my reciver i can always go get another so here we go anyone intrsted if it works ill post how i did it and some pics of the finiushed project
im gonna start build tommorow so if u can help please leave meassage before 5 tommorow
thanks
