Troubles
HMMMM where to start.. Well today I was out bashing the GT and ran into some troubles. A bit about the car first, RC10GT full ball bearing, OS .12CVX(Iknow kinda weak), MIP pipe, and K&N Filter.
Anyway I was running in gravel for the most part, and hitting a small yet acrobatic sand pile, she was running top notch. I was on the 3rd tank of fuel when I hit the sand pile, soared about 3-3½ feet in air and about 6-7 feet out off the top of the pile. The last time I hit it it landed fine and flat, moved about 3 feet after the landing and a loud pop occured and she quit. I only ran full throttle in short bursts(4-7 seconds) and gave it 20-30 seconds in between full bore. Visually nothing is broke and the piston moves freely yet still tight at the top. I don't even have a full gallon of fuel thruogh this engine. But she won't start. Break in was done properly as i took about 8 tanks during the break in procedure. The car is fine tuned and was even richened up a bit to compansate for the cooler weather, tried to lean it out a bit to see if she would go but to no avail. Guess tomorrow before I head to get the TMaxx I should pull her apart and get parts as needed. I need a new clutch anyway, any particular clutch I should look into. Also thought about a different engine, what would you recomend???, I was thinking the Mugen MT12, comments welcome.. |
Troubles
Have you tried a new glow plug?
Troubles
indeed I have. Unfortunately no go on that one either..
Troubles
Strange!
Maybe with the head removed you'll be able to see how the piston travels. I wonder if the con rod has damage to it? Something under stress seems to have caused your now "no start engine" to become sick. :( Sounds like an experienced engine person would be very useful here. How about guys??? Any suggestions? |
Troubles
True there, never really thought about the rod because spinning the flywheel it feels like it should. Was busy today and never got a chance to tear it down or to make it to the hobby shop. As for tonight maybe when I get home, heading to West Seattle to watch a buddies "Blues" band play at a club. If not tonight then first thing tomorrow, thanks for the help Crash, I really appriciate it..
| All times are GMT -8. The time now is 05:23 PM. |
