RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Does this shape matter? (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/4458493-does-shape-matter.html)
joshiestevens 07-03-2006 12:52 PM
1 Attachment(s)
Hi,
I have enclosed a picture of my Cen NT-16 with a manifold I have. It can bolt onto the engine without a problem, but it is a differnt shape, and also the exhaust exit on the engine is a different size to that on the manifold as you can see..
Will it still work fine:
snowbl!nd 07-03-2006 01:55 PM
RE: Does this shape matter?
It'll work as long as there is a good seal between the two, but you'll get much more power if the manifold matches up the opening on the case properly. You could try dremelling it to shape (i've done that do make minor mods on my manifold) or just buy another manifold which matches up better - it'll probably only cost a few quid.
joshiestevens 07-03-2006 02:10 PM
i cant see why there will be a power loss if I have a good gasket.
snowbl!nd 07-03-2006 02:18 PM
It's all to do with air flow - if you prevent spent fuel, oil and gas getting out of the combustion chamber you're robbing the engine of power.
joshiestevens 07-03-2006 02:30 PM
right I see, i need to get hold of a cheap nt-16 manifold and gasket.
snowbl!nd 07-03-2006 02:36 PM
You don't need a NT-16 manifold & gasket - most side exhaust engines use the same exhaust size. Just seems like you were unlucky with the manifold you've got. Take the engine into model shop and they'll probably be able to find a manifold which will match the engine...
joshiestevens 07-03-2006 02:47 PM
right, thanks a lot. ALso, I dont have the original cen pipe, so I am going to be using a standard silver kyosho one. Is that okay, are they all the same inside? I took it apart, its got 2 parts, in the small parts its got a cone inside it that goes very thin at the end. Would the cen pipe be pretty much the same?
dustin7837 07-03-2006 03:12 PM
You would definately be better off with a matching header. like snow said, it has to do with the airflow. You want a nice laminar flow through your exhaust pipe, and the little bit of mismatch there would be enough to cause it to be turbulent.
check out www.customrccars.com for CEN parts.
snowbl!nd 07-03-2006 03:26 PM
Different pipes give different power curves - but as long as it fits and it was designed for a smallblock engine it'll probably be fine. The two cones mean it's a "dual chamber" tuned pipe, which is good.
ASSOCIATED_DRIVER 07-03-2006 04:08 PM
Looking at the photo, the height of the opening of the manifold looks bigger than the exhaust opening of the engine, I dont think this will seal properly. If I am wrong, then the dremeling I would also recomend to widen the header opening to match the engine's exhaust opening. I think most headers opening does not exactly match the exhaust opening, its usually smaller, except on rear exhaust with round ports. This is the easiest mod done with nitro engines which gives it a little more power because the air is not restricted.
joshiestevens 07-03-2006 05:19 PM
ORIGINAL: snowbl!nd
Nope, its just a pipe with one cone at the end, where it goes into a small hole about 6mm diameter or so. Its just a standard kyosho pipe. All I was wondering is if the Cen standard pipe would be pretty much the same, so I wont see any reductions in perfrmance or massive changes in sound.
cenracer1 07-03-2006 07:52 PM
joshie... I just ordered a new cen pipe after a bad crash... don't ask.... its about the same as the one you have... I run an os 18 now.. the exhaust size is the same as the cen comming off the engine.. just dremel the sides a bit to allow better flow... I do that with my cen pipes to allow better breathing.....the cen pipe as well as the kyosho uses pretty soft aluminum so its not hard to do..
joshiestevens 07-06-2006 11:41 AM
I called my LHS and they told me thatg the manifold would be fine. They said the following:
Although the outlet of the engine is wider than that of the manifold, if you look inside the engine, the hole in the piston where the fumes come out is actually no bigger than the hole in the manifold thus there will be no problem with the fumes trying to escape..
It is only a problem if the hole in the manifold is actually smaller than the hole in the pistonn, which you can see by looking through the outlet..
What do you think?
joshiestevens 07-06-2006 04:42 PM
anyone?
snowbl!nd 07-06-2006 04:44 PM
BS. Plain and simple.
joshiestevens 07-06-2006 04:47 PM
it makes sense.. because if you look into the engine outlet. the hole where the fumes comes out of is much smaller than the outlet.
snowbl!nd 07-06-2006 04:54 PM
Yeah, but the exhuast gases don't stay in the same "size" as the exhaust port - they spread outwards. If they're blocked you get turbulence (for lack of a better word) and they can't escape as quickly.
You want to keep their journey as smooth as possible....
joshiestevens 07-06-2006 05:15 PM
im going to try it... I think it is a manifold that came with a tuned pipe for that engine though.
When using the car, what signs should I look for to tell me that the manifold is wrong?
ThunderbirdJunkie 07-06-2006 05:18 PM
looks fine to me...
joshiestevens 07-06-2006 05:29 PM
1 Attachment(s)
Hey, sorry for the bad quality photos, but you can see below what I mean by where the fumes come out is actually smaller then the engine outlet. You can see on the right side of the engine in picture 2, that the inside of the outle is at an agle which feeds into the piston.
snowbl!nd 07-06-2006 05:38 PM
[sm=spinnyeyes.gif] ok then, you use that header [sm=spinnyeyes.gif]
[:o]
joshiestevens 07-06-2006 05:43 PM
well, what do you think i will see go wrong with the car?
Dudelive 07-06-2006 08:33 PM
If the pipe seals properly and there are no leaks you will not have the performance from that setup that you could have. It is the same as porting and polishing heads on real to life size cars, it helps the exhaust escape smoothly thus causing a vacuum effect to allow more out faster. The faster you can get ALL the exhaust out of the enging the faster it can get more in and start over again. It has to get in fast and out fast in order to have the best performance. If you are not looking for the best performance then you may not notice a difference.
I don't run nitro but what I have explained above is the way it should be. If I am incorrect then one of the some of the experienced nitro people will correct me. Thanks
Dudelive
dustin7837 07-06-2006 09:08 PM
ORIGINAL: Dudelive
Dudelive
Exactly!
If you use that header, the car will run, but you will not see the same power or RPM's as you would if you had a matching header.
Like Dudelive said, it's how fast your exhaust gas flow rate is that dictates your intake rate. Haveing the headers not matching will slow the exhaust gas down considerably.
joshiestevens 07-07-2006 02:02 PM
You say there will be a change in RPM and power, btu would that be noticeable. Is it worth chaning if im just driving in a parking lot etc..
ThunderbirdJunkie 07-07-2006 02:05 PM
no, it won't be noticable.
dustin7837 07-07-2006 02:47 PM
ORIGINAL: ThunderbirdJunkie
I don't know about that...
Hard to say I guess. But think in a full size engine, just polishing the ports helps with power.
I'm not saying not to run it with that header, I'm just saying if it's a good engine and you plan on using it, you may as well spend the $5 or whatever for a matching header to have the engines full potential.
ThunderbirdJunkie 07-07-2006 03:43 PM
All i'm saying is that if he's got a Cen with a little .16 he wont' notice. if he was running a high end off road car with a crazy hand modified .12 and had a mismatched exhaust port, he'd probably notice.
joshiestevens 07-11-2006 01:31 PM
The standard cen pipe is dual chambered and has 2 outlets (like a twin pipe). On all other cars I have seen, they just have a single outlet and when I opened my kyosho pipe it had a single cone. Why is this 2-chamber pipe better, and if it was, why dont all manufacturers adopt this.
ORIGINAL: snowbl!nd
snowbl!nd 07-11-2006 02:04 PM
I don't know the science behind it (something to do with resonance pressure waves....) but a dual chamber pipe is better than a single chamber pipe (or muffler). I think they produce a wider range of pressure waves having two chambers, so the ideal backpressure is supplied to the engine at both ends of the throttle range. It may even be that one of the cones has more of an effect at low revs, whilst the other helps the engine when it's revving higher.
I think the number of outlets, or "stingers", is purely for looks as none of the high-end pipes have them. Mufflers and single chamber pipes (i believe you can get single chamber tuned pipes, although i've never seen one...) are used simply because they are cheaper than the 2-chamber tuned pipes and mufflers are much more compact.
EDIT - This is just based on what i've seen. I could be (and probably am) completely wrong.
ThunderbirdJunkie 07-11-2006 02:11 PM
dual chamber pipes vs single chamber pipes depends entirely on WHERE you want to make your power. some engines work better with a single chamber, some work better with a two chamber.
SManMTB 07-11-2006 03:45 PM
Just to cut through the misunderstandings about tuned pipes in this thread.......
A tuned pipe always consists of a header + divergent cone + convergent cone + stinger. That's the tuned part!
2 or 3 chambers is a confusing term and I think it just has to do with the muffler part. Europe now only allows 3 chamber pipes because they are less noisy.
From what understand a 1 chamber pipe is just the tuned part. No muffler.
A 2 chamber pipe is the tuned part + 1 stage muffler.
A 3 chamber pipe is the tuned part + a 2 stage muffler.
[link=http://en.wikipedia.org/wiki/Expansion_chamber]Here is the link.[/link]
joshiestevens 07-11-2006 04:55 PM
hmm - so my 1 chambmered kyosho pipe (i.e just has one cone in it) will be much louder than if I buy a stock cen pipe, which is dual chambered..
SManMTB 07-11-2006 05:18 PM
ORIGINAL: joshiestevens
I have no clue what your pipe looks like or who said it was a 1 chamber pipe. I was just posting what I think it means and what the tuned part of a pipe actually is. The rest is (hopefully) a qualified guess. Nobody I've asked seems to actually know what it means. All I hear is repeats of what a sale broshure says..... if you get my drift.
You say your pipe only has one cone. Does it come apart so you can see it? Just wondering.
joshiestevens 07-11-2006 05:21 PM
SManMTB 07-11-2006 11:23 PM
If you only have one cone and muffler element it will not necessarily be louder. So yeah 1 cone + muffler element will technically be enclosed in one chamber.
(Two cones and no muffler will also be one chamber. Do you see what I'm getting at?)
How do you know it's only one cone?
joshiestevens 07-12-2006 12:00 PM
because i took it apart..
