RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Need advice on this problem iv been having (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/5741801-need-advice-problem-iv-been-having.html)
slick41691 04-19-2007 07:41 PM
Hey, i need some of your views on the dynamite twin peak charger, it seems that every battery i charge with it has a shorter over all life, and isnt as powerfull as it should be. is it me or is it the charger? I do let the batteries cool down for about 20 minutes when they are hot, but i do not fully discharge them. is that a problem?
and if the charger isnt good, what cahrgers do you recomend that can charge two batts at once?
and i just bought new batteries that cost me a pretty penny, and if its the cahrger, i dont wanna use them with it.
joes75 04-20-2007 12:32 AM
RE: Need advice on this problem iv been having
Not familiar with that charger but are you sure your not setting the charging amps too high when you charge them. That will give you a false peak charge on that battery.
miiister-nathan 04-20-2007 04:51 AM
hey guys... ummm i have a problem with my TB-01. i havent driven it for at least 4 months nd its got a problem now. i think theres a problem with the servo it keeps twitching and it accelerates by itself and turns by itself as well.
thanks
miiister nathan
JUCD VPR 04-20-2007 06:11 AM
I have this same charger, my batteries seem fine, if they don't seem as strong for some reason then charge them one at a time on the 1.5 amp side and let them get a really good slow charge. Mine work fine, the only problem i have is sometimes i get false charges fast, so i just swap sides with them and it seems fine or i'll slow peak charge them. My fan acts up sometimes but i just smack the crap out of the charger and it works fine.
Foxy 04-20-2007 06:14 AM
I'm not the worlds greatest battery expert, but I understand that when charging you have two options, a high amp charge to encourage the battery to deliver a high amp output (with a small sacrifice in duration), or a low amp charge, to focus on duration at the expense of 'punch'. That's what I thought anyway, but hey, I'm a nitro man...;)
RCtruckRacer 04-20-2007 09:38 AM
Not all batteries are the same. 2/3 A NiMh cells - typically found in RX packs - have a '1 C' charge rating. Or, they are rated to be safely charged at 1 amp per 1000mah rating of the cell. So, if there were a 2000mah rx pack it could safely be charged at 2 amps. Charging it at 4 amps could kill a cell. Sub C cells (stick pack) however, can usually be charged at '2C'. For instance a 4000mah NiMh stick pack could be charged at 8 amps.
If you are charging you rx pack at 4 amps, you can expect performance to decrease.
Foxy 04-20-2007 09:51 AM
I usually charge my 1400 5 cell receiver packs at 2A. Never seems to hurt them and they charge in under an hour..
slick41691 04-20-2007 06:45 PM
ohh, ok, thanks guys. but i think my question is, since the cahrger i have doesnt have a selectable amp rate and it can only charge at 4 amps. Is cahrging at 4 amps bad?
