RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   RS4 3 EVO rear diff problem (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/6057552-rs4-3-evo-rear-diff-problem.html)
ehroof 07-01-2007 09:06 AM
Hi guys,
i have an rs4 with an os .18 cvrx, i keep ripping out the pinion and larger rear diff gears, i did it within 3 tanks of fuel yesterday, i dont feel any heavy play in the gears, anyone have this problem, any suggestions?
thanks,
eddie
hpi apollo 07-01-2007 12:59 PM
RE: RS4 3 EVO rear diff problem
do you have the hardened gears? might want to get an aluminum gear case
ehroof 07-01-2007 02:53 PM
would you have a link for it, i just use the stock hpi a855. i was lucky to get a few tanks from it yesterday
brokespokes31 07-02-2007 09:40 PM
i still use the stock 1 too , but i fill it with team assos. stealth lube. they last about a half gallon worth of driftn
RLMHPI 07-02-2007 10:10 PM
1 Attachment(s)
I am running the hardned ring and pinion from the .18ss it seemed like the ring gear was different then the original evo ring gear but i bolted it up and have ran over 10 tanks with no problems there are two little bumps on the stock gear that center the side gears inside the diff. The new hardned one didnt have them but it fit and has not given me any problems if you switch to the hardned u will understand what i am saying when you take it apart!!! The hardned gears are to the right you can see the tabs i am talking about on the stock gear to the left!!!
ehroof 07-03-2007 06:45 AM
thanks, i shimmed the big gear yesterday and will run over the weekend and see if that helps, even though they were slipping the teeth werent that bad so i put a shim to move it closer to the pinion and the mesh feels alot tighter.
SteveM 07-03-2007 08:09 AM
I had a problem with the front diff gears on my 3 Evo RTR sedan that was related to a missing ball bearing on the output shaft. You may want to check your diff to ensure there are two ball bearings otherwise the shaft will wobble and ruin the gears quickly like mine did.
ehroof 07-07-2007 05:09 PM
ok, i ran the car and got a 1/4 tank of fuel before they stripped again, i ordered the hardned steel ones so hopefully that will solve the problems, the mechanic at the lhs cant figure it out either, all bearing are there and good, dont understand but the hard steel ones should take care of this, expensive but worth it if it works!!!!!
hpi apollo 07-07-2007 05:25 PM
buy an aluminum diff case too, keeps it from flexing and wearing
ehroof 07-08-2007 11:28 AM
do you have a link for it?
gasdriverca 07-27-2007 08:57 PM
This is good to know guys....I've got an rs4 3evo rtr on the way(brand new).by the sound of all this i'll double check mine for all bearings and screws etc.
