do they make these
i posted this in electric on accident
anyone have a link to a compnay that makes something like http://cgi.ebay.com/ws/eBayISAPI.dll...category=14951 but instead of it having LED display, i want it to have a voltage reading (down to 0.00 ive seen 0.003). one like an ohm meter or even an lcd display. thanks if you know |
do they make these
link doesn't work
do they make these
ok i fixed it
i want one that has a better read out.....the red-yellow-greeen doesnt give me enough information. i want to pop a battery in there and see a read in digital 0.09 volts .....or on a fully charged battery 1.2 volts. |
do they make these
anyone?
You could
Why not get the led display, then if you dont have one, a small digital handheld meter.
I use the handheld as my source, check after every run, but you could leave the led onboard, and use the handheld to verify once in a while. Try to mount the led with vibration in mind... Hope it helps |
do they make these
so guess thats a no ......no one makes what im looking for. maybe ill make one myself.
do they make these
My friends and I just use a multimeter to test individual batteries, and also the output from the leads on packs. It's not this model, but this is the idea of what i'm looking at.
http://www.radioshack.com/product.as...DB6FA3713323CC If you just go to radioshack and tell them what you're looking for, they should be able to help you find one that'll do what you want. |
do they make these
yeah i want read out like that but with the "battery snap in" feature.
i can just solder the leads to a 1 cell battery tray from an old radio i got that takes 1 AA. i guess that would work, i was just looking for one already made. |
| All times are GMT -8. The time now is 12:02 AM. |
