No exaust
Will it do anything to the engine if you take the muffler off the car and run it with out the muffler?
other than making a really loud noise |
RE: No exaust
someone asked this before, and theres a site somewhere that explains all this. im not sure where it is, but i have a vague memory of the reason. the back pressure i think keeps the fuel from going straight through the engine? sounds right to me, but thats just me
RE: No exaust
But will it mess the engine up in anyway?
RE: No exaust
might lower performance and i think i saw somewhere it may be bad...dont be dependent on my memory though
RE: No exaust
I'd imagine it would have a negative effect on performance since the 2 stroke engines we use rely on the pipe dyanmics and backpressure to aid in performance.
RE: No exaust
ORIGINAL: jatoracing33 someone asked this before, and theres a site somewhere that explains all this. im not sure where it is, but i have a vague memory of the reason. the back pressure i think keeps the fuel from going straight through the engine? sounds right to me, but thats just me http://www.rcuniverse.com/forum/m_35...tm.htm#3535977 |
RE: No exaust
Ohh ok thanks
RE: No exaust
do not do it there will not be enough backpressure to supply enough fuel, since the oil is contained in the fuel, there will not be enough oil and your engine will probably sieze up
RE: No exaust
ORIGINAL: mazdab2600 ORIGINAL: jatoracing33 someone asked this before, and theres a site somewhere that explains all this. im not sure where it is, but i have a vague memory of the reason. the back pressure i think keeps the fuel from going straight through the engine? sounds right to me, but thats just me http://www.rcuniverse.com/forum/m_35...tm.htm#3535977 no...i think. i think it was some thread in either one of the mt forums or st forum. well, im off on a search mission;) |
RE: No exaust
this might not be it, it might be. i skimmed through it and i think it will answer your question
[link]http://www.rcuniverse.com/forum/m_6216485/anchors_6216485/mpage_1/key_exhaust/anchor/tm.htm#6216485[/link] |
RE: No exaust
ORIGINAL: s7jstep1 do not do it there will not be enough backpressure to supply enough fuel, since the oil is contained in the fuel, there will not be enough oil and your engine will probably sieze up Read the first four words of his post and you have the best advice for your question. |
RE: No exaust
DO NOT DO THIS. This will make your engine explode. It need the back pressure for the engine to run right. Just keep the exhaust pipe on it. Good luck.
RE: No exaust
Oh ok it. i tried it earlier today and nothing happend... but it sounded cool though and anoyyed the neighbors:D
RE: No exaust
well, you probably just shortened the life of your engine very much.
| All times are GMT -8. The time now is 12:12 PM. |
