RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   cleaning (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/6559691-cleaning.html)
weil0127 10-30-2007 05:08 PM
cleaning
What is the best way to clean you r/c truck after a long day of bashing?
jatoracing33 10-30-2007 05:30 PM
RE: cleaning
this is kinda like a "what should i get" thing...theres no best way. its all a matter of opinion. what i do is strip it down and clean it with denatured alcahol and q-tips. some people take the electronics out and hose it down
nothinbetr2do 10-30-2007 05:39 PM
RE: cleaning
this is what i use, and it works great http://www3.towerhobbies.com/cgi-bin...?&I=LXN287&P=7
GYNAIKAS 10-30-2007 05:45 PM
RE: cleaning
I use a big brush and a toothbrush for the hard spots. I prefer the "disassembling and reassembling" way. And I also use cleaning benzine.
hkenvy91 10-30-2007 06:22 PM
RE: cleaning
try mean green and a compressor then wd with another blow off.
stay away from electronics
nothinbetr2do 10-30-2007 09:01 PM
RE: cleaning
check this out http://www.rcboatmodeler.com/ME2/dir...FB8F9C394488A7
sheograth 10-30-2007 09:18 PM
RE: cleaning
WD-40
46u 10-30-2007 09:19 PM
RE: cleaning
A whole lot better, cheaper and you get over twice as much 32 OZ.
http://www3.towerhobbies.com/cgi-bin...&I=LXWC47&P=ML
Or use denatured alcohol for about $12 a gallon. Always blow off with compressed air.
The Winner 10-31-2007 09:58 AM
RE: cleaning
i wah my truck! lol! i remove all the electric parts and the engine and i wash with water and soap! then i lube all the bearings and put grease at diffs! and clean the engine and put again back and it is ok!
GYNAIKAS 10-31-2007 10:45 AM
RE: cleaning
ORIGINAL: The Winner
Avoid water...another method that I usually see when at the local track is atatching a special tool at the end of the compressor wich blows air mixed with cleaning benzine...it kills every single dust on the car and doesn't harm the electronics or servos when they are turned off. Benzine evaporates instantly.
The Winner 10-31-2007 11:37 AM
RE: cleaning
why to avoid water? i remove the engine and the electronics! and when i want a fully clean rebuild i clean with this way: 1.remove engine and electronics and pipe,2. apply cleaner for motocross bikes(for 10 minute) ,3. drop warm water with presure and clean it well,4. i leave it in the sun, 5. unassample all the car and the bearings clean with dw-40 and then i lube them with bearing oil ,6 clean all the car, lube all the moving parts,put grease at diffs,seal some points,polish all the metals,put the electronics,6. maintance the engine and put at the car,7.polish the pipe 8. clean the body! and at some plastix i drop in a towel wd-40 and i clean the plastic parts and is like new!
GYNAIKAS 10-31-2007 04:50 PM
RE: cleaning
It's just that it's not good for the plastics to dry at direct sunlight...and water doesn't evaporate so easily...anyway if that's easy for you there's no problem. I'm just saying that there are easier ways with less effort. Just be sure that ALL the water goes away.
proptop 10-31-2007 09:55 PM
RE: cleaning
Unless you are extremely careful, it's all too easy to get water into the electronics...not good...
I just wipe off the big chunks...and use an old tooth brush and q-tips and an old T-shirt...but I don't worry about getting it too clean, cuz it's just gonna get dirty again :D
calvino 10-31-2007 10:00 PM
RE: cleaning
ORIGINAL: proptop
same with me. a stiff tooth brush works BEST;), I am an elec guy so that is why[8D]
The Winner 11-01-2007 05:12 AM
RE: cleaning
i said that i remove the electronics!
proptop 11-01-2007 05:53 AM
RE: cleaning
That's good...
But not everybody wants to go through that every time they clean.
I've seen guys just turn the hose on their truck and flood everything...:eek:
A guy brought a truck into the shop one day..."it doesn't work"...
When I opened the radio compartment, water droplets were sitting on the Rx. and inside the Rx. case was condensation. I dried things out with a hair dryer and got it going again, but there was evidence that water had been in there before, and for some time, because all the wires had corrosion on them.
