Battery
whitch is a good battery brand and number to get the longest run time out of. also looking for a good price . i seem to run out of my battery after like ten min. of runnig it hard that sucks. i have a 2000 and a 1500 . i know that those are a small number compared to the 3200 and the 3800 but where can i get the best price at? i need a 7.2 v .
RE: Battery
It really depends on how much you're looking to spend and what kind of battery charger you have. If you have a charger that can charge Nimh battery packs then I'd suggest getting something like this: http://www3.towerhobbies.com/cgi-bin...&I=LXLZK6&P=ML
RE: Battery
im looking into a battery charger, that will charge two batteries at once now that you saY that what is better NIMH OR NICD? i am just getting started so i want to get the things that will last the longest . wow that 4200 probably will run for a while . my 2000 doesnt last long now . im looking into that inellipeak dual pulse charger which says it will do both . but now i need to know what batteries are better ? NIMH OR NICD
RE: Battery
NIMH! never get nicds. you need to completely run down nicds before you can charge them, otherwise the develope a 'memory' and wont hold full charge again, they also wont last as long as a good nimh.
RE: Battery
Most chargers will charge NiCd and NiMH. But yeah definitely get NiMH, their much more reliable. I wouldn't get anything lower than 3000 mah.
RE: Battery
NiMH is definately the way to go these days. You'll see significant improvement over the nicds. About the only thing nicds are used for today is for things like my roto start or toy type RCs. If your on a budget you should check out the tenergy cells. They not as good as the IB cells or new Ener-G cells but they would be a significant improvement over what you have and are more budget freindly.
RE: Battery
lipo... lipo... lipo...
sorry couldn't help myself, I'm mostly a heli guy. |
RE: Battery
Lipo is the way to go !
RE: Battery
Lipos are definately nice and if its in your budget go ahead and do it. In this case it will probably be expensive for him to get into. You'll need a different ESC(or a low voltage cutoff) 30-$100's, a lipo capable charger $40-$150, lipo battery, 50-100's. So, if you get off cheap your probably looking at $120 which isn't too bad. You'll like the performance and runtime advantage if you can afford it.
RE: Battery
ORIGINAL: rideon20z im looking into a battery charger, that will charge two batteries at once now that you saY that what is better NIMH OR NICD? i am just getting started so i want to get the things that will last the longest . wow that 4200 probably will run for a while . my 2000 doesnt last long now . im looking into that inellipeak dual pulse charger which says it will do both . but now i need to know what batteries are better ? NIMH OR NICD Lipo is a nice if you have the money but you'll get more run time out of Nimh. What I mean is that for the price of one Lipo you can get multiple nimh batteries where the capacity will be much greater overall. As time goes on Lipos will come down in price and make them the standard but more than likely we're years away from that. Of course Lipos have more voltage which is why most people go for them but that is another story. As said above most chargers that can charge Nimh can also charge Nicds. |
RE: Battery
Try venoms
RE: Battery
avoid venoms
RE: Battery
1 Attachment(s)
Hello ,
i recommend Ni-MH 4800mAh 1.24V batery to you. the left picture is the results tested by TM-8. so I assure you the quality. By the way ,we have been an OEM for many years. better bigger and affordable than you can imagine. Any quetion interests,feel free contact me E-MAIL:[email protected] MSN:[email protected] |
RE: Battery
ORIGINAL: rideon20z whitch is a good battery brand and number to get the longest run time out of. also looking for a good price . i seem to run out of my battery after like ten min. of runnig it hard that sucks. i have a 2000 and a 1500 . i know that those are a small number compared to the 3200 and the 3800 but where can i get the best price at? i need a 7.2 v . |
RE: Battery
ORIGINAL: rideon20z im looking into a battery charger, that will charge two batteries at once now that you saY that what is better NIMH OR NICD? i am just getting started so i want to get the things that will last the longest . wow that 4200 probably will run for a while . my 2000 doesnt last long now . im looking into that inellipeak dual pulse charger which says it will do both . but now i need to know what batteries are better ? NIMH OR NICD Ni-MH is better than NICD, it can last for a long time, and the capacity is also higher.in addition, our company also have charger especially using for Ni-MH, if you need, please feel free to contact me. |
RE: Battery
ORIGINAL: H-energy Hi, we are professional manufacture of high power battery, our battery are safe,long life cycle, the price is also decent, the 7.2V Ni-MH we have is 1500mAh, 4300mAh and 4600mAh, please check our website: www.henergy-battery.com, email: [email protected] |
| All times are GMT -8. The time now is 08:03 AM. |
