RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   engine problem (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/7456087-engine-problem.html)
buggyracer5 05-04-2008 08:10 PM
engine problem
MY motor runs fine at full throttle, but when I let off the throttle and it will not idle, it stalls. Im pretty sure the needle valve is tuned properly, but I could be wrong.
sheograth 05-04-2008 08:12 PM
RE: engine problem
Check your idle adjustment screw and/or the throttle linkage and trim. Basically you want to make sure that the carb is NOT being fully closed when it should be idling. With the engine off, remove the air filter and take a peek. At neutral, the carb should be cracked open a bit to allow an idle.
experimental_pilot 05-04-2008 11:09 PM
RE: engine problem
It could also be the LSN is too rich. When you close the throttle it loads up with fuel.
raymanh 05-05-2008 10:51 AM
RE: engine problem
At idle the carb should be open 1mm.
