RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   Speed control question (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/7720297-speed-control-question.html)
hondacr9 07-11-2008 05:44 PM
Hi guys,
I'm new to the sport and just got an RC10 T4. It has an LRP AI speed control and i have a 7.2v 3000mAh battery. My problem is that if i have the wheels turned and then try to give it some throttle, it wont go but you can hear the motor buzzing. When i let go of the steering wheel the car will go. Do i need a bigger battery or is it a bad ESC?
andrewtexas123 07-11-2008 06:04 PM
RE: Speed control question
That's a confusing one and haven't heard of it before! I don't think its the battery you might want to try and get a new esc but wait for other people to respond after me as I am not positive..
Andrew
Druss 07-11-2008 07:28 PM
What's the voltage on the fully charged battery?
hondacr9 07-11-2008 07:30 PM
ORIGINAL: Druss
8.0 Volts
Chris_RC 07-11-2008 08:10 PM
are you sure you have the pinion gear set screw on tight? That or maybe a blown diff gear or spur gear?
hondacr9 07-11-2008 08:28 PM
Yes,
The tranny and motor are fine. It's a brand new RTR truck and its done this right out of the box. The light on the ESC has been flickering and doing some weird stuff as well.
andrewtexas123 07-11-2008 08:31 PM
If its brand new I think the esc is done.. It should be under warrenty so I would replace it if I were you..
Andrew
Druss 07-11-2008 09:21 PM
Ya, if the battery is good then it's either the esc or motor. Sounds like the esc though as it's having trouble putting out power to both the steering servo and the motor at the same time.
suburban_hooligan 07-11-2008 09:59 PM
have you driven the truck before? if not you might want to check the throttle trim on the radio (make sure its at 50/50), and reset/reprogram the ESC as per the instructions
arcticcatwill 10-06-2008 08:49 PM
maybe slipper is set to loose?
sweendog1969 10-16-2008 10:31 PM
i also have a speed control question. I recently scored a 1/6th scale nascar off ebay, however it is the basic version and is not digital proportional and i was wondering if anybody made a 12v speed controller?
I am not affiliated with this guy but if your like *** is he talking about this site will set it straight http://www.1-6thscalenascarrccars.com/
