Eddie???
Hey Eddie I will be ordering the tuned pipe for my truck (it will come tomorrow) but will this part also fit my truck : 02031A Polished Aluminium Manifold+Pad
RE: Eddie???
yes it will but the header that comes with it is a good one also, its not a manifold like some of the older style hsp rc's
RE: Eddie???
Ok But I did notice that the Polished Aluminium Manifold is a bit shorter than the one that comes with the truck.. but your saying that they are roughly the same though..
RE: Eddie???
its a non restrictive header, the 02031a is a shorter one but i think with the gearing you want a little more torque, its just my opinion but i left the stock header on all my megap's and used the 02124 pipe on a few of them.
RE: Eddie???
Ok I might still get it cos its only 6 bucks I think.. Oh something else how about coming out with a Metal drive gear (Spur gear) so we could replace the plastic one cos I would be first in line to buy some ..
RE: Eddie???
we are working on that but the megap's gears are really good, we have no real problem with them, if meshed correctly you good with them. I like plastic because it keeps the shock off the diff gears.
RE: Eddie???
I know that your right Eddie but I'm gonna fit a .21 in the truck later on so I'll need a metal gear for that extra power.. I see it that a 1:8 truck should have a .21 engine in it "LOL" so I'll need this parts to beef up my truck (I hope that you have them in stock)
mpo-01 Wheel Hex Set $13.00 mpo-02 C HUB , C HUB PIN $38.00 mpo-03 Knuckle Arm Set $33.00 mpo-04 Rear Hub Set $33.00 mpo-5 Shock Stay Mount $29.00 mpo-10 Brake Post $6.50 mpo-11 Steering Rod $13.00 mpo-13 Slipper System $6.50 mpo-14 (903-004) Aluminum Shock -2PCS $24.00 mpo-15 (002124) Aluminum Exhaust Pipe $22.50 02031A Polished Aluminium Manifold+Pad |
RE: Eddie???
lol, no problem bro, all in stock, i am also getting a shipment of sh.21 engines in too, should have this week!!!!
RE: Eddie???
That's great eddie. How much is the sh.21 though??
RE: Eddie???
should go for 89.99
RE: Eddie???
Ok thats a good price but will I need a differenet engine mount to fit it into the MXT-2S...
RE: Eddie???
Since the .21 is a big block you will probably have to redrill the chassis and you could use the original mounts, i put a .26ss in a mamba and i had to change the mounting holes in the chassis, we also have adjustable motor mounts that may work good too. You will have to use a different flywheel, clutch shoes and a clutch nut, when you are ready, i will give you a list of stuff you will need, i have all that you will need to do it. :)
RE: Eddie???
Thanks Eddie Could you do the list for me today if you can cos I'm going to do this project right away, so I'll get those parts first and a spare chassie just in case I screw up redrilling the holes LOL..
RE: Eddie???
lol, i dont have the engines yet, should have them in a day or 2.
RE: Eddie???
I mean the engine mounts and the clutch stuff..
RE: Eddie???
i will work on the list today bro :), worst case, i will get it to you tomorrow.
RE: Eddie???
Hey bro,
you will need the following: 81020: http://server.sohouniverse.net/~himo...&=SID#MOREINFO 81203: http://server.sohouniverse.net/~himo...&=SID#MOREINFO you could use the stock pipe but you will find it better with a 1/8 pipe: http://server.sohouniverse.net/~himo...&=SID#MOREINFO i am pretty sure you should be able to use the stock motor mounts, you will just have to drill the chassis, you could try these: http://server.sohouniverse.net/~himo...&=SID#MOREINFO |
RE: Eddie???
Thanks Eddie your are the main guy and YYYYEEEE HAAAA my truck came WOW I didn't know it was THAT BIG LOL and The quality is perfect maybe I could use my wife as target practice with this huge truck...
RE: Eddie???
lol, now be nice, lol. Make sure to give it a good once over with the screws, do a good break in and take some pics and video's!!!!! most of all, have a good time with it.
RE: Eddie???
I'm not sure if I'm gonna run it in cos I got the urge the fit the bigger engine.. how many teeth are on the trucks clutch bell Eddie??
RE: Eddie???
i am 99% sure its 17 tooth, run it bro, you will like it, its fast stock out of the box.
RE: Eddie???
Ok I will do..
| All times are GMT -8. The time now is 04:47 AM. |
