RCU Forums
-   RC Car General Discussions (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/)
-   -   dual engine nitro (https://www.rcuniverse.com/forum/rc-car-general-discussions-179/9548674-dual-engine-nitro.html)
doug702 03-02-2010 01:07 PM
dual engine nitro
i have 2 og xtm mammoths and want to make one of them twin 457 powered any thoughts or ideas on helping me achieve this would be appreciated</p>
Marine Brad 03-02-2010 01:26 PM
RE: dual engine nitro
Have a look at this for some inspiration!! :_)
http://www.modelsport.co.uk/?CallFun...n&ItemID=33525
sheograth 03-02-2010 02:13 PM
Wow that Schumacher is really cool.
asupervee72 03-02-2010 05:06 PM
that thing looks sweet, i was reading it has problems with the belt drive system though, i like how it's more of a two cylinder then a dual engine
J.D.T 03-02-2010 08:43 PM
a local did a savage xxl with .28 twins but went for one motor on the front diff and one on the rear using jackshaft style 3.0:1 reduction boxes with monster kongs for snow bashing
mrsmartjohnson 03-03-2010 08:35 PM
ORIGINAL: asupervee72
I heard that also it did some research and it seems that that was on prototypes with not enough tension from the belts! The same belt system was used to deliver the new guiness world record speed from a shumacher belt driven car!
doug702 02-17-2011 05:11 PM
i have finally acheived what i set out to do in the gallery section type in xtm mammoth mine is the one with 2 engines and no control arms of tires on it i dont know how to post a pic in this forum
doug702 02-17-2011 05:14 PM
better yet just click on my gallery its pics are there
378 02-17-2011 05:21 PM
Not bad at all. If it were mine I would run matching engines just to ensure the powerbands line up, but nice job. I want to see it run!
doug702 02-17-2011 05:33 PM
ive got matching engines in the mail i just used these as a mock up its gonna have 2 xtm 457's
ElectricGuy007 02-17-2011 05:42 PM
ORIGINAL: doug702
Im not a huge fan of nitro but i have to say your project turned out better than expected.
I noticed the two engines are different, I figured they would need to be exactly the same,
or youd risk over heating one of them. Electric is like that I dont know about nitro.[&o]
Oh and to answer your next question try www.photobucket.com and start you a free account and copy
your photo to this website. This website has been on the fritz latley and everyone else here has been using it.
doug702 02-17-2011 05:46 PM
thanks. i figured out that you just click on my gallery to view photos but i will try the link to
doug702 02-17-2011 05:47 PM
i may need assistance in posting a video on youtube if anyone knows how
378 02-17-2011 06:10 PM
ORIGINAL: ElectricGuy007
Glow engines only overheat if they're A: run lean, B: have no airflow, or C: have an airleak. Running two mismatched engines in a vehicle like this won't overheat either of the engines, although the clutches might not be all that appreciative. They'll have to take up the slack of the differing powerbands. If the gearing isn't overdone then the clutches should live fine even with mismatched engines but I still would rather have matching ones.
Ideally I'd lock the cranks together with a chain or something. If one wants to flame out the other one will force it to keep turning, and the vehicle won't get shaken to pieces as quickly.
doug702 03-17-2011 04:39 PM
i just finished my twin engine mammoth ill post pics later tonight
Sigma.40 03-17-2011 05:34 PM
Nice work! Definitely want to see a video. Let us know how the dual engine affects the speed.
doug702 03-18-2011 03:46 PM
1 Attachment(s)
heres a pic of my twin
Sigma.40 03-18-2011 04:58 PM
<span style="font-size: xx-large">VIDEO!!!!<span style="font-size: smaller"></span><span style="font-size: small">That is an awesome looking RC and I want to see and hear it run.</span></span>
doug702 03-18-2011 05:40 PM
ill work on the video
Sigma.40 03-18-2011 05:46 PM
How do you start that thing? Can you start 1 engine at a time or do you have to start them simultaneously?
378 03-18-2011 05:48 PM
Most likely one at a time.
doug702 03-18-2011 05:53 PM
one at a time
doug702 03-18-2011 06:45 PM
ok so im 3 tanks in to the break in process and am starting to have a problem. any advice would be appreciated the motor on the right runs good with good smoke trail the motor on the left has thicker smoke trail and gets much hotter than the other one. on another note the right motor cuts out sometimes thanks in advance
378 03-18-2011 06:54 PM
Left engine: Thicker smoke trail AND hotter? Well...that's a new one to me. I'd guesstimate either bad fuel, an exhaust leak somewhere(This would cause piss-poor fuel pressure in that engine's tank, which would cause it to run funny), a pinhole leak in the fuel line, cracked tank or perhaps an air leak on the engine itself.
Right engine: Check the plug and make sure that is good. Break in is notorious for munching plugs, and usually when an engine cuts out and it's not an air or fuel issue it's a bad plug. Could also be bad fuel, I'm assuming you're running the same stuff through both engines.
doug702 03-18-2011 07:11 PM
yes im running same fuel through both engines and its a brand new gallon of fuel i bought 2 days ago i have presure and fuel lines split off the one tank i dont think presure is a problem same with fuel lines and both plugs are new, in my gallery of photos there is this mammoth with 2 silver heads it was set up slightly different but i never had this problem and yeah as far as the left engine getting hotter i to am stumped ive checked lsn and hsn settings and idle screw settings both are the same. ill check for an exhaust leak
