Help understanding radio gear
Hi,
I have a CLOD BUSTER that I will be customizing.
I currently want to get it up and running and the last thing I need is radio gear.
My intention is to have two servos to drive the 4 wheel steering, one front and one back. I want to be able to switch off rear steering on the fly. So that requires two channels.
I will also be running two ESCs as it will be brushless running on LiPo and last time I looked there is no ESC that can handle that.
The question is do I need a 4 channel radio or can I run a 3 channel with y harness connecting the two ESCs (I want them running at the same speed!).
The next question is how do I know that the radio gear I am looking at has the capability to do what I want to it to do. Is there some terminology that I am not familiar with that will tell me if it does this?
For instance I've been looking at these:
KYOSHO SYNCRO RADIO SET KT331P Tx Rx KR331 2.4 Transmitter
http://www.ebay.co.uk/itm/3316892006...%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/2217256848...%3AMEBIDX%3AIT
http://www.ebay.co.uk/itm/1615969276...%3AMEBIDX%3AIT
Any advice is very gratefully recieved!
Andy
Andy
I would recommend going with a 4 or 5 channel controller. forget about doing the y connection. It is always better to ad more channels then if you need them for upgrades later you have them.
Look at this controller, it will do everything you need and more....https://www.spektrumrc.com/Products/...ProdId=SPM5000
Thanks, Marty.
Thanks, Marty.
