The new Airtronics M11!!!
RE: The new Airtronics M11!!!
I just found the spect on the radio.If any one interested...
Newest model out, be the first with this new controller.
1. Adapt the new feature of ‘Extreme High Response Technology'.
‘The quick response technology', has been in great demand since we released the ‘M8', has updated to the breaking point and adapted to ‘M11'. This EHR Technology incorporates the opinion of drivers and allows you to enjoy the greater sense of operational feeling.
2. Using PPM – 2 or 4 channels respond to all RC vehicles.
As PPM is adaptable for all the RC vehicles such as racing car, buggy, Monster truck and etc, all the users can enjoy at any circumstances. By changing the module, you can use both 40 MHz and 27 MHz.
3. Customize (key assign)
By putting into ourselves in our customer's shoe, we introduce new product, has the entire manual operation button which can be fully customized by users. All of our customer can enjoy M11 and they get fun from it!!
4. Computerized Multi Function Display (CFM Display)
The large sized CFM Display (240 x 90) allows you to confirm any information you need. Back light will be adjusted to blue or white color.
5. Ergonomic design and rigid body shell
The handle features and ergonomic design of elastomer grips on the handle and this soft rubber grip makes it easy to hold. High-traction provides you the precise movement of the wheel.
6. Other new functions on M11
• Throttle Tension Adjuster
• Vibrator function (Grip)
• Traction Control System
• ALB(Anti Lock Break)
• Trim Position Adjust (5 Position)
• Steering Height Adjuster (2 Position)
• Trigger Tension Adjuster
• Brake mixing
• EXP can be added to the ARC adjustment
• Full Adjustable Rate Control
• Variable servo speed adjustment
• Servo Monitor
• 30 Model Memory
Includes:
- Transmitter (M11 for RC Car)
- Receiver RX-311 super micro 27 mhz FM PC/PPM
- Transmitter module
- Display Protective Cover
- Power Switch
- Transmitter NICD Battery
- Transmitter Battery Charger
- Instruction Manual
• Brake mixing
• Servo Monitor
• 30 Model Memory
Includes:
- Power Switch
ORIGINAL: Seiki
Do you need the spektrum?
I want the radio should i get the spektrum for it too?
For a Monster Truck not really, unless your an expert modifier and can set up duel servo front & rear brake controlled buy 2 servos for better braking control, adjust on the fly for freestyle. Also 4 wheel steering operated buy 2 servos.
I have the MX3 and the M11 I can feel the speed and response in the steering and with traction control on lose tracks works well for my revo and savage.
If you run 1/8 buggy or road cars the braking options are unlimited.
I say if you got the $$ do it you’ll love it. But if you just running a stock setup car (RTR) naa go with hitec Aggressor srx or Airtronics MX3.
But if your running a few hot rods or even like me 1/8 hydro's, front wing control will keep me from flipping my boat. I'm rigging my out board hydro to have trim control on the fly to keep the 60+ speed in control.
Have fun r/cing
Shumzz
Have fun r/cing
Shumzz
