Radio Controler
RE: Radio Controler
FET is field effect transistor. Probably in an amplifier circuit in the receiver. Sounds like some sort of marketing hype. Just get yourself a decent 2 channel radio and don't worry about FET, it isn't likely a real requirement.
What are you looking to spend on a radio?
PA
RE: Radio Controler
They probably meant b.e.c. ( battery eliminator circuit) which will allow you to run off the 7.2v pack instead of a seperate receiver pack. What radio do you currently have? That will determine what receiver you want to use.
