RCU Forums
-   RC Car Radio Equipment (https://www.rcuniverse.com/forum/rc-car-radio-equipment-201/)
-   -   Lynx 3D Module problem (https://www.rcuniverse.com/forum/rc-car-radio-equipment-201/1909146-lynx-3d-module-problem.html)
ac112785 06-16-2004 09:58 PM
ok I just got a Lynx3D radio and the module specifies ch.76, but I went to hitec's website and it said for best performance use the matching Tx crystal, but it says you can also use any other 75mhz tx crystal with no problems. Well I was setting up my radio for my car and truck and I felt heat coming from the radio. At first I thought it was my batteries, then I noticed the module on the back was heating up. I turned it off and I dont want to do anything until I know what's wrong.
ac112785 06-16-2004 09:59 PM
RE: Lynx 3D Module problem
in case anyone is wondering I was using hitec 75mhz ch.68 Tx crystal
ac112785 06-17-2004 01:00 AM
ok i just found out whenever a crystal is in the module the thing heats up, so maybe if i use the listed channel crystal is might not heat up. i'll try, but has anyone else had this problem
