Return of Lunchbox..
#2726
RE: Return of Lunchbox..
experiment!
thats the fun.. i mostly use mine on-road with a 8.5brushless system in it so i have my suspension as hard as possible.
i only have one problem though, it keeps throwing one of the rear wheels off, i have tried nylock nuts but they ar'nt strong enough, when i run out i will try some flangetype locking nuts, after that it will be threadlock, although this does tend to damage plastic so wowuld be a last resort
#2729
yeah stock wheels, the only modifacations are the esc/motor, cva shocks, metal bearigs, i tried swapping the wheel left to right but its always the right rear that comes loose, i might try swapping the half shafts to see if it is them,
#2732
they are both novak ss5800.
i bought 2 because i have found a way to join the m-03 and m-04 together, just waiting for somone to make a body i ike to fit because it is now 250mm, i have motors and esc's everywhere, when ever i buy a kit i always get a sport tuned motor too, so i have 3 standard silver cans and a spar sport tuned and 2 spare teu-101bk's.
the novak in the LB swaps from there to the m-04 for the custom chassis. on carpet it handeld a bit too well.. on full lock and on power it dug the outer wheels in and turned over!
#2733
does the axle on the right side stick out as far as the left? if it does, the problem is not with the axles, so disassembly would be a wasted effort.
<edit>
what i'm saying is, if the wheel nuts get on the axle completely, the problem is the nut, not the axle
<edit>
#2734
oh yeah the gearbois perfect, i just wanted to eliminat a problem with the thread on the shafts, maybe even swapping from left to right will cure it because i think its the rotation direction of the wheel that is undoing the nut, if the thread is bit weak them swapping it from left to right will have the effect of tightening the nut on the weak shaft.
just a thought
just a thought
#2735
this just occurred to me.....
if i remember correctly, i think the shafts are 2 different lengths, aren't they? if so, you won't be able to swap.
anyone have a copy of the manual handy?
#2737
ORIGINAL: lbshelfqueen
#2739
[link=http://m03]http://www.youtube.com/watch?v=AkxZUlw5ItI[/link]
see for yourself, this was just to see if would blow up, its on a wet road with no corners but you get the idea
#2740
Did you all glue your tires to the rim?
I know Lunchboxer had to because his brushless is so fast. BUt i have not yet and one of the front tires only came off twice.
#2742
ORIGINAL: Lunchboxer
Always glue tires to the rims! [:@]
#2744
Then SS4300 is not fast enough!! (joke)
#2747
#2748
ORIGINAL: rcluke
the link isnt working
Or just klick it in my post. lbshelfqueen botched the link.
This is how it should have been: [link=http://www.youtube.com/watch?v=AkxZUlw5ItI]M03[/link]
#2750
[link=http://www.youtube.com/watch?v=AkxZUlw5ItI]m03[/link]
try that link.
the shell is a kamtec shell for a mardave, it is 205mm wheelbase, with a bit of carefull trimming fits an m-03 perfect, it would fit a lunchbox too but is too wide in my opinion
try that link.
