Return of Lunchbox..
#1477
FL
RE: Return of Lunchbox..
wow - thanks for going above and beyond on the help. i truly appreciate it. i will pick up those pieces when i go to the hobby shop. can't wait to see what the lunchbox can do with real shocks!
#1478
ORIGINAL: juiceman
#1479
well, it's kind of a weak solution to my problem...but oh well...
i decided to go with the XL-5 esc new, and am going to use an adapter on the battery. that way, the connectors stay stock & the lifetime warranty on the esc (good lord i hope i don't have to use it) will only be $20 instead of $35. much mo better.
got to drive my lunchbox today in what felt like forever. i remember it being faster, but i've been driving the brushless pede, so i guess that'll do it to you. it's all good though, i'll be driving the lucnhbox for a few days i'm sure!
#1480
FL
well i thought i would share some pictures of my lunchbox/ monster A-team van .
it has full ball bearings hpi saturn 20T motor futaba S3003 servo with a R152JE futaba reciever and futaba MS contoller i will be upgrading the esc to a futaba MC230CR ESC w/Reverse 20T esc which should be here in a few days from tower all that will be left is upgrading the shocks. let me know what you guys think. ill post more pictures of the finished van when its done
#1484
FL
well she is done. may i present to you fine folks my lunchbox/monster A-team van....BA would be so proud. let me know your opinions on the finished van. oh yea i had to keep the vanessa licence plate to pay homage to the lunch box
#1486
I pity the fool who doesn't like your LB!!
ORIGINAL: Aslvrfrost98csvt
#1488
nice, it's about time someone got the 3tone right on a box shell,
i'm sick of seeing black with a red stripe and no silver
#1491
Aslvrfrost98csvt
nice paint job...but i think is something wrong with the tyres...
what will do the ESC MC230CR, better than the stock ESC?...and why are this motor better?...
sorry for those Q, but tryng to understand and translate isn't easy all the time..
rcluke
nice composition....baaad pic...sask someone to delete them...or you can edit the post, bring something better, we know U can...
rcluke
#1492
that esc can only handle a 20t motor...don't see how it could be better than the teu-101bk...that is a great esc, it just doesn't handle high power motors
#1493
FL
the tire was put on backwards .thats what happens when little kids distract you and as far as the stock esc it was defective so i used it as a excuse to get a better one. and yes i read the set up instructions on the esc still doesnt work. the new esc plus some debonder and more CA glue i still come in under my 400.00 limit. so i can get some stuff done to my svt
#1494
FL
here she is after a day of adventure and out running col. decker . once again the A-team is triumphant over the forces of evil.(enter theme song )
#1495
FL
what modifacations do you have to make to put the xl-5 stampede front shocks on the LB and will that help with the bounce you get with the stock shocks?
#1499
FL
anybody know how the tamiya upgrade shocks are
http://www2.towerhobbies.com/cgi-bin...?&I=LXGG67&P=7
#1500
ORIGINAL: broncojd
this is from pg 18...go there and you can read all about it, with pictures...
you need 2 sets of the front shocks traxxas stampede/rustler/bandit shocks. or the rc10, or hpi rs4mt, rs4mt2, or any other 90mm shock. the rear will fit fine, but the front will need a spacer put inside the shock to limit the travel by about 1/2 a cm. otherwise the camber on the front end will be outrageous.
ORIGINAL: broncojd
AHAHAHAHAHAHA!
finally, the oil-filled shocks came and are installed. HOLY COW...can i get some camber?!
these are the stock front shocks from the traxxas stampede, rustler, bandit, and sport. i used front traxxas shocks on the front and back of the 'box. i got the shocks from the new XL-5 stampede that come with white springs. i painted them to match the body of the lunchbox. however, they are friggin' STIFF! what weight oil do you guys use in your lunchboxes? when i replace the oil i'll put in some spacers to fix that camber.
up next: the wheels for the 2.2 tires i recently bought and some of the oil shock brackets to attempt the 3rd shock.
check the pics...pretty sharp if i say so myself.
AHAHAHAHAHAHA!
