Tamiya TB-01 Resource Thread!
#353
RE: Tamiya TB-01 Resource Thread!
ORIGINAL: Lunchboxer
Nice.. I guess the package got to Romania okay?! ha!
#354
for sure the hop-ups list must have some strong dumpers on it...the plastic ones looks pretty fragile in hard terein, where the WRC will perform...:d
Any suggestion...???
#357
I am guessing that most of those HPI shells come without holes drilled... ?! If they are pre-drilled, most likely they won't line up w/ the Tamiya body posts..
Yeah, you'd need some offset all around to fill the shell.. to be 10mm wider, you'd need extra 5mm offset on each side.. I know HPI sells standard, 3mm, and 6mm offset wheels..
Good luck and keep us posted!!
I've thought about the R35 from Tamiya however the R32 just does it more for me (in RC scale, real life R35 all the way!)
#359
Not yet.. been too lazy to cut the shell and paint it up!! ha ha!! Will do so soon enough.. that's my next project...
ORIGINAL: cornel4web
I think so...did you manage to paint the shell...just for having impressions about the fast tb-o1...
#361
CA
Cornel, You build your rc cars in front of your computer? Did you forget your pants that day? Haha.
Also, didn't you get the Subaru 2001 Prototype? That body looks like a 2004 model?
Cheers,
Skottoman
Cheers,
Skottoman
#362
LOL...you are right...LOL...
yep, the quick build don't leave me time for cut and painting the body...also my fobia of painting bodys are the other reason not finishing yet the 2001 prototype, which are my favorite scooby shell...hope one day to get a finished one...even if the interior will not gonna be seen...
#363
#366
ORIGINAL: rcluke
has anyone got the rally germany subaru impreza tb01 ?
Matt
#369
so, LB, can you list your hop-up used on your TB...just not to forget what you install on it, until really hit the road with it...
#370
Not much, really.. just the aluminum center driveshaft (replaces the steel one), and the light weight TB Evo gear set (plastic one replace the metal ones..)
Everything else = stock..
Of course, now the new alloy motor mount..
But that's it... !!
But that's it... !!
#373
CA
My TB02 seems to be fine with the Sidewinder 4600. I'm sure the TB01 would be fine as well.
It is possible to strengthen the drivetrain of the TB01 to TG10 Nitro standards, and I'm sure that would handle anything, as my TG10 does with my 1.5 HP .18 OS engine.
Reinforced driveshaft, Metal diff gears, Metal ring gears, Hardened outdrive cups, TG10 LongArm Universals (you know there are actually 2 different diameter axles), would all make the drivetrain almost bulletproof.
Cheers,
Skottoman
Cheers,
Skottoman
#374
The TB-01 comes w/ metal ring gears.. I actually purposely change them out for plastic ones.. I wouldn't worry about the Tamiya plastic gears.. if anything, I have more faith in them than the pot casted metal units... I know not everyone shares my view, though, ha!!
#375
ORIGINAL: skottoman
Cheers,
Skottoman
Cheers,
Skottoman
