Go Back  RCU Forums > RC Airplanes > RC Combat
I have the kit, now how do I build it? >
RC Combat Discuss rc combat planes, techniques and strategies here.
Old 04-21-2002 | 06:11 PM
Default I have the kit, now how do I build it?
I have a combat gremlin kit and a giant piece of paper with the plans on it. Not much sequence detail.
How do I build this crazy thing?
I have built a few kits one from Dynetech, one from Goldberg and one from Lanier, but I must admit they had some nicely detailed step by step instructions.
Does anyone have a step by step list for building a combat Gremlin?
My .40 size motor is getting anxious for battle!
Old 04-21-2002 | 07:32 PM
Default Go here
Click here This is a link to RC Modeler on the web. Click on COMBAT GREMLIN . Then use WEAKSIGNALS as the user and toledo2002 as the password. RCM gave out this access at The Toledo show it will only work for a limited time.
Enjoy
Old 04-24-2002 | 12:40 AM
Thanks!
This is great!
Combat awaits!
Old 04-29-2002 | 12:49 AM
OHIOMARK
you can go to racores website ,that the guy who makes them
CORO KID
Old 04-29-2002 | 08:50 PM
You want a good word of advice from a guy that's been flying them for over 10 years? Get a solid 1/8 fiberglass rod(48") and put it behind the LE. Take your dremel tool and cut a little slot in the foam just big enough to fit the rod in.Glue it in with epoxy and glue the LE on top of it. Also use 2" wide stapping tape across the LE and two strips all the way around the wing at the two wing bolt blocks. You're going to need it if you are going with anything bigger than a .25
Old 05-03-2002 | 12:02 AM
A fellow clubmember put together a very good guide to building a gremlin including pictures.
Gremlin Instructions
I think you will find it very helpful.
Jerry
Flying Eagles, NH
Old 05-03-2002 | 01:29 AM
racores.com
my site
Old 05-03-2002 | 01:40 AM
Old 05-08-2002 | 01:10 AM
WOW!
Again thanks for the help!
Old 05-11-2002 | 11:18 PM
This the most fun you can have with your pants on.
The gremlin once set up and balanced properly is one
awesome flyer with a good .40
Old 05-12-2002 | 12:01 AM
kramer's Avatar
My Feedback: (61)
Kramers Combat Spads
I can't agree with you more
