Go Back  RCU Forums > RC Airplanes > RC Combat
Direction Of Corrugation >
RC Combat Discuss rc combat planes, techniques and strategies here.
Old 04-30-2002 | 12:47 AM
My Feedback: (33)
Default Direction Of Corrugation
HELP, I JUST RECIEVED 12 PIECES OF CORO CUT TO MAKE A DERELICT WING AND HAVE HAD THEM CUT THE CORRUGATIONS WRONG.
THEY RUN THE LONG WAY INSTEAD OF WITH THE CORD.
CAN I MAKE THE WING WITH THE PIECES I HAVE AND HOW WILL IT EFFECT THE FLYING AND STRENGHT OF THE PLANE OVERALL.
THANKS FOR YOU HELP
AIMING@U
Old 04-30-2002 | 10:06 AM
Each wing half can be seperate pieces, so no problem cutting one of your sheets in half and using the pieces to build a chordwise fluted wing. When the wing is done, put a center wrap around the middle and go flying!!!
Not at all! In fact if you look at the construction of the Debonair, which is a 60" wing span trainer, the wing is built in two halves!
Old 04-30-2002 | 01:27 PM
My Feedback: (33)
THANKS FOR THE ADVICE, I WILL MAKE THE WING IN TWO PIECES. I TRIED TO MAKE IT WITH THE CORDS RUNNING THE WRONG WAY AND IT JUST DOESN'T WORK VERY WELL.
