Go Back  RCU Forums > RC Airplanes > RC Combat
 CONFUSED ABOUT SSC WEIGHT >
RC Combat Discuss rc combat planes, techniques and strategies here.
Old 12-04-2003 | 03:35 AM
combatpigg's Avatar
Default CONFUSED ABOUT SSC WEIGHT
I've been to the RCCA site and have read the rules for OPEN COMBAT. The weight rule given for class A was a MAX of 2.5 pounds. The weight spec for SSC was given as a minimum of 2.5 pounds. I figure that SSC would fall under the same general rules as class A OPEN, so I just want to be absolutely sure about this before I finish building my SSC ships
Old 12-04-2003 | 06:24 AM
Default RE: CONFUSED ABOUT SSC WEIGHT
SSC planes have to weigh at least 2.5 pounds or more
A class planes have to weigh 2.5 pounds or less
Old 12-04-2003 | 10:36 AM
combatpigg's Avatar
Thanks TATTOO! I was hoping that the wording at the RCCA site was a typo and that a SSC plane could run in class A with just an engine swap. I guess a dual purpose plane is possible if there was a way to add and subtract useful weight. thanks again!
Old 12-04-2003 | 11:50 AM
It is actually possible. My SSC planes weight in just under 2.5lbs, so I tape on some lead on the CG to make weight.
However, I've also found that my SSC wings are too slow for A class, so I while I do use the same fuse, I swap wings betweent the two classes. Same root chord and same airfoil, just smaller span for A.
Oh, and A and SSC really aren't directly related. It's better to think of them as seperate classes, even though they share the same engine dispalcement.
Old 12-04-2003 | 12:55 PM
combatpigg's Avatar
Thanks again KIRK! I guess with a multi purpose design you end up with too many compromises. I'm going with a flying wing and a unremovable tongue hanging of the front to mount the engine, so my design is less versatile than yours, but they sure went together fast!
