Go Back  RCU Forums > RC Airplanes > RC Combat
 EPP Foam Suppliers >
EPP Foam Suppliers
RC Combat Discuss rc combat planes, techniques and strategies here.
EPP Foam Suppliers
Old 01-25-2004 | 09:40 PM
Default EPP Foam Suppliers
Does anyone know where I can purchase EPP Foam for building?
I have found a few sites but they have limited sizes available.
Old 01-25-2004 | 11:13 PM
TT2
My Feedback: (13)
Default RE: EPP Foam Suppliers
[link=http://www.rpvi.com]http://www.rpvi.com[/link]
I've ordered from Rick before and he's great to deal with. If you're looking for larger sizes then you may be out of luck...from what I remember the EPP billets are formed 24" x 36" x 4" max...at least that was the case where Rick gets his from. Splicing it together for longer cores is no problem...just use some 3M77 to join the EPP.
-Tom
Old 01-26-2004 | 10:04 AM
Thanks for the info TT2.
A chunk of EPP 24"X36" should be big enough for a couple of sloap soarers. That is the biggest piece of EPP that I've heard of yet.
Do you have any info on cutting EPP? I've cut other types of foam but have never used a hot wire on EPP. What temperature range should be used, in comparison to blue or styrene foam?
Thanks!
Chris
Old 01-26-2004 | 03:17 PM
TT2
My Feedback: (13)
Cuts about the same as EPS but you may need slightly more heat. Make sure you have plenty of ventilation! The gases produced are toxic...so I've heard.
-Tom
Old 01-26-2004 | 05:50 PM
TT2
Thanks for the info. I looked at the rpvi website and found the prices and sizes to be pretty good.
Thanks for the help!
Chris
