Wonder Speed ?
I don't have access to a radar gun but mine is pretty fast with a .15 FP and an 8x4 prop weighing in at 29 oz.
The real problem is the plane is fairly small so you'll want to keep it close. Mine actually flies pretty smooth going flat out.
Kevin
Kevin
Yeah, mine is pretty fast and smooth too. However it is quite a bit heavier than yours - it weighs 35.5 ounces with 3 standard S3004 servos and a 600 mAh battery pack. I am guessing that you are using smaller components, no?
Does anyone know how fast these things fly?
NC
OK first what is everyones "best guess " of how fast their Wonder flies flat out ? 60 MPH ? More ?
Im putting in a MDS .18 but I only have one servo right now, a Expert SL300 which will probably go on elevator. What servos do you all recommend for ailerons ? I was thinking a HS-225MG ?
Would I do better to put some kind of mini servos for ele & ail ?
Guess I'll go with a HS-55 for throttle.
What are your suggestions ?
John
John
Should be fast then huh?
