Reflex and the Falcon 72
GA
Set the aileron parallel to the bottom of the wing then add about 1/16" at the back edge of the aileron. This is a good starting point. The Falcon will take all the aileron you give it but be darned stingy with the elevator. It is really pitch sensitive. About 3/8" up is all you will need.
