Go Back  RCU Forums > RC Airplanes > RC Combat
Carbon Fiber and Rip Stop??? >
RC Combat Discuss rc combat planes, techniques and strategies here.
Old 08-25-2002 | 02:22 PM
Default Carbon Fiber and Rip Stop???
I recently saw a combat plane that had a foam core and had a carbon fiber spar and leading edge and was covered in rip stop. I was wondering where these items can be purchased and how to apply them to the foam core.
Old 08-25-2002 | 04:50 PM
aseaholm's Avatar
Midair,
The items you talk about are the latest building techniques in Open combat. Very simple and very durable for minimal expense. The rods I've been using are 1/8" - 5/32" diameter solid fiberglass. Fiber glass is stronger then carbon fiber, not as stiff but considerably cheaper. They can be purchased on line from these:
www.intowind.com (upto 48" rods) approx. $1.00/each
www.kitebuilder.com (upto 72" rods, the way to go if you building long wings) 72 inchers approx. $2.00/each.
Ripstop nylon or plain nylon can be found at most fabric stores. Walmart usually has plain nylon on the $1.00 rack, can't be picky about colors but for a buck you can't go wrong. Most people have been using water based polyuerathane from the hardware store. 10 dollars for a quart, which will do about 12 wings.
The foam is high-load from either Dow or Dow Corning. Insulation dealers usually carry it. The 40 psi crush seems to be the best combination of weight and strength.
Mike Fredericks at [email protected] cuts CNC wing cores for a very reasonable price if you're not familiar with burning, I mean cutting foam cores.
There is a lot of information @ www.rccombat.com under the Topic Forum about these topics. If you do a search on any of these topics you'll be reading for hours...
Good luck...
Old 09-05-2002 | 02:29 AM
Thanks.
How do you apply the ripstop?
How many pieces, 2 (top and bottom)?
How far do you overlap it?
Old 09-05-2002 | 02:59 AM
Go to www.georgiacombat.com
He has complete instructions. I don't do the hot water thing anymore and it works just as good for me. You'll see what I'm talking about after you read the instruction.
