The weight of the open B
OR
Is the 3.5 lb weight with gas on board or without, and is the fuel bring it your own or they provide you with in caompetition( Paris, Texas)???
THank you
THank you
OR
THanks for the info.
Does anyone know what is a good nitro to run in the Norvel revlite, i am running 15 % and i get about 17.5 k Rpm, WHat are you all running.
THank you
THank you
I was running 10% SIG 25% castor fuel in my CL combat plane with the BigMig25 on the nose with no problems. My last match though my pitman got a syringe of 35% in the bladder by accident. Now I know you figure you'd wonder what was up when you had to adjust the needle after 3 matches of not touching it, but I was in a rush but MAN did that engine scream, up till I centerpunched the other guy. If you are blowing plugs, add head shims or back off on the nitro, but there is lots of power out of normal fuel so you don't have to buy more expensive, less you want to.
