shark combat plane
Hi ya all! Does anyone know where I could find plans for the shark combat plane?The only info I could find is that a guy was building these models out of his home named SHARK MODELS no info on shark models on the web.Any information would surely help!! Thank you in advance.
I manufactured the Shark about 5 years ago. I now make the Lethal Weapon which is a 59" pink foam wing, aluminum rails for the fuselage, coraplast tail surfaces. It has balsa ailerons,hardwood spars, plywood wing saddle mounts and comes with the hardware, pushrods, control horns and wing hold downs. It sells for $35.00 plus shipping. You can contact me at [email protected]
FL
The Guy Building Sharks is Roger G. He is a member at our club. You may contact him here [email protected] He has a full spec sheet and can supply you with all of the information that you need. It's a blast to fly. They bounce cool. Sometimes you can keep the engine running after ya skip it off the grass at blinding speed.
