Shredder version 2.2
1 Attachment(s)
I just finished this one over the weekend after busting the third gutter pipe fuse. coro fuse with light ply on either side. Got rid of my v tail and shortened it up a little more. need to go weigh it yet but it looks mean enough. Started out life as a devistator, all that is left is the wing after 3 combat weekends. Should get to test fly it this week if the wind lays down a little
RE: Shredder version 2.2
Lost aother half pound in this design, just weighed it in at 4 pounds. the gutter fuse version was 4.5
Looks like a nice target,, err I mean design.
Flew it last night, big differance from the first version. I think im going to like it.
Btw, I noticed you have a Macs muffler on there. You do realize that the Macs muffler is a muffler, not a tuned pipe, right? A mousse can will give you a noticeable power boost over that muffler.
Yep, i ran a tuned pipe for a while and did not like it that well. I switched the stock muff for the macs i picked up used and did gain a few R's i think a thousand or so but i have not played with the mousse can yet. where is the best source of info on building them? the old super tigger could use all the zip i can muster.
I'm not sure why your worrying about RPM's. Ya know a noisy motor doesn't make up for lack of talent!!! Butterfly V15 gonna whup butt. Shredder V-2.2 is going down!!
http://mywebpages.comcast.net/webmaster01/ For Mousse Can and Header.
http://www.harborsales.net/ For 2mil coroplast. |
Mousse cans can also be found at www.flyingzhobbies.com check the special products section. These mousse cans have proven to increase rpms on .25s swinging MA 9X4s by 2,000 rpms. They developed them initially for the fun fly competitors many years ago and have a lot of experience with them.
Whenyou guys get the Avengers flyin you'll forget all about the coroplast. Then maybe if I tie one arm behind my back someone might be able to take this trophy off me. I tried to post a pic of it sittin here in my living room but I can't figure how.
Rick |
ORIGINAL: Rflyin Whenyou guys get the Avengers flyin you'll forget all about the coroplast. Then maybe if I tie one arm behind my back someone might be able to take this trophy off me. I tried to post a pic of it sittin here in my living room but I can't figure how. Rick Thanks for the info, and dont forget, if i had not blown off the first two streamers at the the throttle up that trophy would have had a different home. Gave away 320 points right there. You are right though, this wing is limited and hloding me back a bit. I figure if i practice with it and the short span that trophy will be mine.... |
Ifa.....wuda......coulda
Rick |
1 Attachment(s)
Is this the hardware you all are a wantin. It goes back up for grabs October 2nd. Makes your mouth water doesn't it!!!
1 Attachment(s)
Just thought I'd post these pics from our June event. they are my favorites. Yep that's the Butterfly!
1 Attachment(s)
Ok, I think I got it figured out. This should be a pic of the current home of the "Hell over Hillside" Trophy with it's attending security.
ORIGINAL: Rflyin Then maybe if I tie one arm behind my back someone might be able to take this trophy off me. Rick Ok, the gloves are off old man.... by the way, ive seen you fly, you better keep both hands on the box! Now if i can just find a small enough motor, i can come out and play with you boys. Aaron signed me up for the D-troit event last night, should be entertaining. Sean |
You mean the RCCD contest on the Aug20th weekend?
I should be there. It should be a heck of an event. |
Yep, thats the one. Just went and picked up an OS fx25 over lunch. Take it home tonight and break it in and pipe it up so i can be ready to run with the Big Dogs. There has got to be more than .84 hp hiding in that little engine.
Are we gonna try to practice this weekend?
Rick |
yes, im around this weekend, probably going out for a while tonight if things work out. Need to change out the throttle servo but that should not take long if i still have a spare. A little breezy tonight but it may lay down a little later.
I'm in for a Sunday practice. Say around noon? The Butterfly needs to stretch it's wings a bit.
2.2 met with an early demise friday evening. Version 3.0 will be out This morning for testing. I think its the last of this generation. I like the new fuse and am going to give up on the old beaten devistator wing after this one. Probably switch to a foam wing simular to the avenger. Its just kind of fun to experiment. Ill try to get a pic of this one before it gets sacraficed. went to tripple layer 4 mill fuse with thin ply outers and a 1/2" cutting board MM. Should be fun.
1 Attachment(s)
End of the line. Sun morning we did a little practice combat with the newest design and while the shorter fuse did make some noticable improvements the flat bottom devistator wing really showed its limitations. I like the new fuse, 3 layers of 4 mill coro and a cutting board engine mount but the wing needed updated. I crashed it out sunday and ended the shredder line for good. After flying onr of Ricks planes i can see the need for a better air foil. I think i will finish the avenger this week and start on my own garage version after i see how it flies.
Last pic of the shredder 3.0 |
lol u call that practice on sunday he he !!!!!!!!!!!!!!!!!
Yep... We can call it "practice building new".......... That was a harsh morning!! But O what a blast!!!
4 planes up... 3 planes in the trash when it was over... Gotta love combat!! Man I still love that 2nd or 3rd round when it was You (Corey) Sean and Rick.. that was a great round!!! I hate to say it but the "OLD MAN" was the only one who went home with as many FLYING planes as he showed up with. |
| All times are GMT -8. The time now is 04:32 AM. |
