TT01 stance
IL
TT01 stance
Alright, so I have a TT01 and I found a body at the lhs, looked big enough, took it home did a sick paint job. The problem is it's a bit to wide, Itried using traxxas hexes off the the front of a slash to widen the stance a bit but they wobble on the output. Is there any other way I can widen the stance a bit?
IL
RE: TT01 stance
ORIGINAL: narwalrus
It's most likely a 200mm body and the TT01 is 190mm wide but is really closer to 185mm. I'd look for offset wheels somewhere between 5-7mm.
